Question about Black & Decker Saws
Saw blade model cs144b 5 in. 14 volt saw. can i put diamond blade on my saw.. were do i buy it. ken kenburdzy@juno.com
  • kenburdzy Jan 26, 2009
    HI BLACK &DECKER #CS144B 14.4 CORDKESS 51/2 IN.BLADEOR 5IN. KEN
  • David Ford
    David Ford May 11, 2010
    What is the brand? Does your inner flange have a diamond on it. Let me know the brand and exact model and I will try to help
  • 2,176 Answers
I've looked at both the manual and breakdown and don;t see a diamond flange for this tool, but you might want to call 1-800-544-6986 (Dewalt) and ask them if they offer it. It might be that they do but don't advertise it. Good luck
Posted on Jan 27, 2009
Need manual sabre saw model 900.272510
That's a discontinued Craftsman model.
If you need replacement parts, you'll probably find that parts are difficult to find and way overpriced from Sears.
I'd check into used saber saws on CraigsList.
I needed a blade hub for a worm drive saw for a Craftsman saw and they wanted $46 and it would have to be ordered. (Its a flanged spacer that has the diamond shape that fits in the diamond knock-out in the blade.) The exact same part was used on several other brands including Milwaukee, Hitachi and Bosch. I bought a Bosch one from a local tool store for under $7.
Oct 18, 2014 | Saws
I am looking for a supplier that carries replacement parts for the old Diamond Laser 3000 (not the XL)
Check this website . I think the site supplies parts for Diamond band saw. You may want to check sawblade.com if you need blades . I made several orders with them. It has been a great experience with them.
Aug 03, 2013 | Diamond Tech Diamond Laser 3000 Dl3000...
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
When turning off saw, blade continues spinning for 90 seconds or more.
Unfortunately, this is common on older model table saws. They do not have a blade brake and as far as I am aware it is nearly impossible to retrofit them.
If this is a newer model saw it's likely that the blade brake is malfunctioning and I have no experience with them.
Hope this helps and am very sorry if it doesn't.
Ken
Apr 13, 2011 | Craftsman Saws
The diamond insert in the hub of the blade keeps falling out as soon as I start a cut. What is wrong?
DO NOT USE SAW!!!
1. switch off saw, remove cord from socket (positive electrical insulation)
2. lift table for maximum cut and check size of the washer holding the blade,
3. you should have holding nut with collar, collar is about 1 1/4 (32mm) diameter, then blade (diamond is actually universal reducing bush in some blades) and lastly you should have internal washer, again, about 1 1/4" (32mm) diameter. if your collar are smaller, you need to replace blade as not suitable for your particular model, albeit I am rather suspicious that you have wrong collared nut and internal collar. Please check if both collars are exactly this same diameter. Please check if collars cover diamond cut-out.
4. if you see discreptancy between description in 3, purchase suitable blade (external diameter is 7 1/4" (184mm), as you did not supply what model of your saw, therefore most probably shank is 5/8" (16mm),
5. mount internal bush (collar), will go correctly only in one way.
6. mount blade (pay attention to cut direction, cutting surface should be clockwise if you look at mounting shaft.
7. mount external flared nut
8. check blade for slippage and wobbliness
9. connect power cord and switch on/off
10. check saw blade againg for slippage/wobbliness
11. make test cut if 10 was correct
12. use normally
Do not forget that this is not a toy, it will cut through wood, ocassional nail and your fingers.
Opearating saw crate flying debris, always wear googles or facemask, you have only two eyes and there is no spares.
Please leave note how you go with this advice.
Aug 18, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Blade slips and doesn't turn, but the saw keeps going
Check the blade centre bolt for corrct tightness. If you have fitted a new blade, check to see if it is the type with a removable centre spacer (multi fit type) if it is, it sounds like the centre bolt has bee overtightened at some stage and deformed the spacer which now takes all the drive from the motor instead of the blade itself. Try giving the spacer a light file to remove any burrs. If all else fails, obtain a new blade which doesn't have the center spacer to avoid this problem
Apr 12, 2010 | Ryobi 7 1/4 In. Circular Saw W/ Dual...
How to I change the blade on a skilsaw cicular saw?
The blade is USUALLY held by a LEFT HAND thread bolt. Sometimes they have a diamond insert in the blade that must be removed if the saw has a matching boss on the arbor. If the saw has that, you punch the insert from the blade and engage the diamond over the boss on the saw then put the clamp washer on top and then install the bolt.
OFTEN there is a button near the blade are to push in to "freeze" the arbor so the bolt can be removed/installed. These are USUALLY left hand threaded bolts.
Sep 14, 2009 | Bosch Saws
How do you remove the blade on tile cutter model mk470 mk diamond products, inc
Unplug the saw, raise the guard fully, grasp the blade to hold it and loosen the nut then remove the blade.
Sep 12, 2009 | Mk Diamond Products, Inc. 7 In. Wet...
Need to change the blade on a plasplugs diamond wheel wet saw
The shaft threads seemed to be stripped and you may have to get a set of Torx bits or if not then one bit for the torx screws to take them off. If the threads are stripped on the shaft then you may have to replace it.
Ken S.
Mar 23, 2009 | Saws
Tile Saw Troubleshooting
options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Aug 27, 2008 | Mk Diamond 5.3 amp Tile Saw
Saws Logo
57 people viewed this question
Top Black & Decker Saws Experts
Ruben Bustamante
Jason
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
