Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Freezer doesn't freeze in winter?
We have a RCA Frigerator/Freezer Side by Side MSX20GA located in our garage as a spare/storage frig/freezer. Only during the winter months the Freezer doesn't freeze. But come spring/summer months as it warms up, it works again. We live in wisconsin so the winter months get really cold - even in our attached garage where the fridge is located. Is there something I can do to have the freezer work in winter? Any advice would be great...
    President:
  • 1,214 Answers
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
Posted on Jan 26, 2009
Whirlpool Gold side by side frigerator freezer ice and water not working, inside frigerator various places freeze, on certain shelves units only 5 years old
As far as the icing up sounds like your cross over have ice. Unplug and defrost even on frost free. Should solve both problems
mike
Dec 19, 2017 | Whirlpool Refrigerators
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My frig. in the garage.. The freezer works great in summer months but in winter months it doesn't. Why is that?
Good day,
That is normal. The thermostat that runs the whole machine is located in the refrigerator compartment.
When it reaches normal temperature, it shuts off. In winter months that may mean as long as 12 hours or more. Thus not enough running time per day to keep the freezer near it's normal temperature.
Engineers design domestic refrigerators to be in an area comfortable to humans. Normally 70 degrees or higher. Thus your problem.
The only solution is to bring the machine inside.
Sorry.
Thank you for using FixYa
Dec 29, 2009 | Refrigerators
Refrigerator is freezing
if you turn up the temp in freezer and down on frig side and frig still freeze's than more than likly you have a bad frigerator thermastate.
Nov 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Milk lunch meats freezing
I have to assume you mean on the top shelf of a refrigerator. If so, then you need to look for the air vent(s) that are usually in the rear of frig compartment either on back wall or under the frig compartment ceiling. These vents are pouring very cold air from the freezer and the air needs to get distributed throughout the frig, however the coldness is falling on the milk or meats that are in the way (getting hit with the cold before the air is disipated within the frig).
Three options: if the air vent(s) have a movable or directional cover, then redirect the air so it blows away from the food on the shelves. If there is no movable cover, perhaps adjusting the freezer control (not the frigerator control) to the next colder freezer setting; this will reduce excess cold flow pouring into the frig. 3rd, make a shield of plastic or metal or cardboard to divert the direct cold flow of the air vent from falling on the upper shelves.
Oct 11, 2009 | GE PSC23MGMBB / PSC23MGMCC / PSC23MGMWW...
Frigidaire side by side frigerator freezer keeps freezing up. HAve to unplug to defrost and it works ok for about a week, then no longer cools frig side but frosts up the entire freezer area. unit 9 years...
I too had an aging frig with a similar problem. It's probably either your defrost timer or the defrost heating element. If you're handy, you can troubleshoot the problem yourself by following the suggestions found here. It's not a complicated fix, but if you are uncomfortable taking your refrigerator apart, then contacting a qualified repair person may be your best bet. Hope this information helps!
Aug 23, 2009 | Frigidaire FRS6R5EMB Side by Side...
Freezer works but frigerator does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 14, 2009 | Refrigerators
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
Apr 06, 2009 | Frigidaire Freezers
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
372 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
