Question about Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR
Sterling faucet in stall shower how do you get the handle off
I could see two screws under the handle that turns the water on but do not see any way to get the handle off
  • Anonymous Feb 10, 2009
    The handle of my Sterling shower has a plastic plug that is half blue, half red. I can pry it out of the handle, but there appears to be nothing inside that allows me to pull off the handle. How does the handle come off?
  • 10,865 Answers
Unscrew those screws and the handle will either pull off or unscrew.
Posted on Jan 26, 2009
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Have a two handle Sterling shower stall. The shower head is leaking from the cold water inlet. Believe need a replacement stem. Have changed the O ring but has not stopped the leaking. Is there any...
The part # you supplied is for a shower door and has no bearing to your question. There is no relationship. However, I can say there is no adjustment for any two handle shower stem or even single handle stem. Very rarely will just replacing an "O" ring stop a drip unless it it from through the stem itself and comes out under the handle. When in doubt replace the whole stem...shortcuts will only exasperate the problem. There are no shortcuts in plumbing.
Oct 24, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
How do yor remove a shower control to fix leaking water does not turn off complete I took out screws but can,t seem to pull off the handle
handle has a plastic lid that pops/pries off and has a screw under it. Make sure to turn off the water supply to the bathroom or house before you pull out the cartridge.
Sep 27, 2010 | Delta & Single Handle Shower Faucet
How do you tighten or remove handle on a danze shower faucet
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
Jul 02, 2010 | Danze & Single Handle Tub And Shower...
My shower seems to run even after closing the shower to off position. the water is coming out hot?????? thankyou JOHn Vancouver
REPLACE THE CARTRIDGE. TURN OFF WATER, REMOVE HANDLE AND FACE PLATE. REMOVE TWO SCREWS UNDER PLATE. PULL OUT CARTRIDGE AND INSERT NEW. REASSEMBLE
Jan 06, 2010 | Delta & Single Handle Shower Faucet
No water
the screw should be a phillips head or allen screw
May 28, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Step by step instructions for Moen 82496CBN
You need to loosen the two screws that attach the faceplate to the control valve on the outside of the shower stall. You should be able to pull the valve away from the stall and place a one or two inch board between the valve and the shower stall as a shim. Vary the thickness of the shim until you are flush with the handle, then secure the shim.
May 10, 2009 | Moen & One Handle Tub & Shower Faucet
Sterling One levr faucet
The problem is that the supply lines coming into that shower faucet have been installed wrong. In other words, the cold is on the left side and the hot on the right side, just the opposite of what it should be. This is an easy fix if you can get to the pipes feeding the shower.
Apr 14, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Sterling shower faucet
The problem is that the supply lines feeding that faucet are reversed. That is the cold supply line is feeding the hot side of the faucet and the hot supply line is feeding the cold side.
The fix is to reverse the supply lines where ever they can be most easliy accessed.
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR Logo
539 people viewed this question
Top Sterling Plumbing Home Experts
john h
Mike
Rabbit Brains
Rabbit Brains
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
