Question about ASUS P4S8X-MX Motherboard
Sata hard disk can not detect on asus p4s8x-mx
When turn on computer, hard disk cannt detect. for this problem i reset the computer that hard disk cant detect .
finaly i must shutdown and trun on computer to solve this problem
  • synthdance19 May 11, 2010
    Could you try attending some English as a second language classes and see if that helps?
Go into BIOS and set the SATA controller to native mode. Then your XP disk will find it.
Posted by synthdance19 on Jan 26, 2009Could you try attending some English as a second language classes and see if that helps?
--Maybe you could try helping instead of being a giant tool.
Posted on May 11, 2009
    Genius:
  • ASUS Master
  • 1,102 Answers
Okay are you getting any error messages on startup
or just that it does'nt detect harddrive
Posted on Jan 27, 2009
Thansk i have the same proplem and ur firstSolution its work
Posted on Jul 29, 2010
MY BIOS IS NOT DETECTING SATA hard disk, i system is not detecting SATA hard disk
When the system is booting go into the bios settings. The option for sata drive detection may need to be turned on there, once verifying that option is on save & reboot the pc and it should detect the sata drive.
Mar 14, 2011 | ASUS K8V-MX Motherboard
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
Hi my ASUS K8S-MX motherboard is not detecting SATA hard drive and Sata DVD Writer. Though my IDE hard drive and DVD Writer is working fine. Please help me with this .
Two thing here that can be the issue.
1. Bad Sata controller onboard
2. Sata controller is disabled in the bios.
The Fix
1. Purchase a independent sata controller there like $25 bucks.
2. Try going into the bios under advanced and make sure its not disabled.
I sure hope this finds your Very Helpful vote! Have a Merry Christmas and a wonderul New Year!
Dec 07, 2009 | ASUS K8S-MX Motherboard
Asus K8VMX board didnot detect SATA hard disk
Sounds like you just need to install your SATA drivers. Look around for your cd/floppy disc of drivers if you have any. When you boot from the CD, It will ask you if you have any other drivers you would like to install, thats when you install them and it should read your SATA hard drive just fine. If you dont have your driver CD anymore search ASUS's website or just google (or similar search engine) your motherboard and look for drivers. Beware of some phony sites though. Good luck :)
Jun 17, 2009 | ASUS K8V-MX Motherboard
PATA SATA PROBLEM
This motherboard does support SATA. Check out the specs on the ASUS website:)
http://www.asus.com/products.aspx?l1=3&l2=14&l3=225&model=754&modelmenu=1
Dec 30, 2008 | ASUS K8V-MX Motherboard
Asus p4s8x-mx support CD
If you want a copy of the CDs contact Asus by clicking here and ask if they can sell you a replacement cd for your model.
Instead of getting a replacement CD you can download and run the drivers from Asus download page here:
DRIVERS for Asus P4S8X-MX Motherboard
Sep 05, 2008 | ASUS P4S8X-MX Motherboard
Usb
http://www.driverfiles.net/Bios/ASUS/P4S8X-MX/download/page,sh,29990,172,6,.html
download your drivers here
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
ASUS P4S8X-MX Motherboard Logo
1,439 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
