Question about Honeywell Enviracaire 16200 Air Purifier
How do you reset the filter light after you have changed (vaccuumed) the filter
I lost my instruction boklet for my air purifier and it's a liftetime filter that u just have to vaccum when the light goes off. But how do you reset it once u've changed/vaccuumed the filter? I think it had something to do with the speed control switch but I can't remember. Can someone help?
Hold down the power button for 5-10 seconds
Posted on Aug 14, 2007
You have to pull out both filters top and bottom at once. Then hold down the on/off button for 5 seconds.
Posted on Jul 26, 2007
SOURCE:
Change filter light won't go off
The Change Filter indicator light is controlled by a timer, rather than detecting the condition of the filter. After changing the filter, hold down the timer and speed buttons for about 5 seconds. This turns off the indicator light and resets the timer.
Jul 22, 2011 | Vornado AQS35 Air Purifier
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
How do you change the filter? My in-laws have lost the instructions for their purifier.
You have a Honeywell air filter. Turn it over and there is a big handle which is a screw in the middle. Unscrew it and then lift the entire unit up without the outside screen protection. The filter will have a black pre-filter attached by velcro. Remove it, take outside put on the grass and hose out against the flow of air. (squirt from the inside out to remove stuff). Then use vacuum to blow the filter from inside to the out. Then vacuum the filter from outside in. Let the pre-filter dry. re-install in reverse. If there is a warning light, run on full, then push the warning reset for 10 seconds or more to turn it off.
Mar 01, 2011 | Duracraft DA5010 Air Purifier
Change Filter LIght
take somthing with a small tip, above the light there is a small hole stick it in lol. good luck!!!!!!!!!!!!
Nov 11, 2008 | Honeywell HHT-081 Air Purifier
Honeywell HFD-135 -- lost instructions -- how do i clean removable filter?
Manual can be found here: http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=47a366c04a65e77c69850893b979e142
Sep 10, 2008 | Kaz Honeywell QuietClean HFD-135 Air...
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Manual for Oure Ion Advanced
    the clean filter light will reset itself once the filter is completely clean. Try dust off the areas where the filter is inserted into as well.
    Oct 30, 2007 | Brookstone Pure-Ion UV Air Purifier
    Dirty filter
    Noggin's solution is correct.  My copy of the BAP825 manual says to poke a paper clip into "the hole marked RESET."  There is no hole marked 'reset' on the air cleaner.  Thanks, Noggin!
    Apr 05, 2007 | Bionaire BAP825-U Air Purifier
    Honeywell Enviracaire 16200 Air Purifier Logo
    484 people viewed this question
    Top Honeywell Air Purifiers Experts
    Bill Long
    jdthefixer
    Pierre Laplante
    Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
