Question about Gateway GT4016 Desktop PC
Compatible motherboard for Gateway GT4016 Case
My son's Gateway GT4016 blew the MB. I built him a new computer and now have the Gateway GT 4016 case and some components and would like to use it, but the MB is on the right (from the back) side. What motherboards will fit in this case? Can I put a left side MB in some way?
Thanks
  • sidfink43 Jan 27, 2009
    I may not have been clear on my question. Facing the case from the rear the MB is attached to the right side panel so that the expansion slots are on the lower right corner of the MB if you look into the case with the left (from the rear) panel off. The ATX MB's are attached to the left side panel so they don't seem to fit in the case.
    Thanks for any suggestions.
  • Matrix2142 Feb 15, 2009
    that case takes a micro BTX board only! I am having an issue
    finding a btx board with the 939 socket I need for the AMD
    processor as I ruined to original board while attempting to remove
    a jammed video card. If you find one let me know.
  • Gateway Master
  • 4,806 Answers
Any Micro ATX motherboard will do for that case type
Good luck
Posted on Jan 26, 2009
Will a msi kt4v motherboard work in a gateway gt4016 desktop
The Gateway GT4016 is a 6-Bay Micro uBTX Case and the MSI KT4V is a ATX motherboard. Therefore the Motherboard will NOT fit in the gateway Case.
Jul 07, 2014 | MSI KT4V (MS-6712) Motherboard
Gateway gt4016 motherboard
It has Parallel ATA
PATA or also generally known as IDE,
http://en.wikipedia.org/wiki/Parallel_ATA
1) Harddrive:
101311 - Western Digital, 200-GB, 7200RPM, PATA harddrive,
http://support.gateway.com/s/PC/R/1008842/1008842cl2.shtml
2) Motherboard:
105553 FIC KTBC51G
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553nv.shtml
Product Views; F - Primary IDE Connector,
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr7.shtml
Left side of motherboard, near the black long Ram Memory slots.
This is where the Harddrive plugs in.
Product Views; E - Secondary IDE Connector;
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr6.shtml
Near the black long Ram Memory slots, and next to the blue Primary IDE Connector.
This is Serial ATA, or also known as SATA,
http://en.wikipedia.org/wiki/Serial_ATA
Uses this style of SATA data cable, and connector on motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
(NOTE* Color does NOT matter for cable connector.
Color really doesn't matter, for a SATA connector on the motherboard, either.
You are supposed to plug the Primary SATA harddrive, into the SATA 1 connector, on the motherboard.
The beauty of SATA is, that you can plug into any Ol' SATA connector on the motherboard, that you want to.
BIOS will find the harddrive with the Operating System on it, and will find all the other SATA devices plugged into the motherboard, too )
You do NOT have SATA.
Regards,
joecoolvette
[You may be interested in this,
What's Inside: Computer > Computer Hardware > Explore These Categories,
http://computer.howstuffworks.com/
Also to the left;
Computer Peripherals
Computer Security
Computer Software
Internet
And,
http://www.hardwaresecrets.com/
Click on the headings at the top;
Case, (Computer cases), Cooling, CPU, (Processor), Input, Memory, etc.
Has basic information leading up to technical ]
Nov 30, 2012 | Computers & Internet
My Gateway GT 4016 starts up , loads windows, and goes to the desktop screen then shuts down. The power supply, hard driive, ram and video card are all ok so I think the motherboard is shot. It is a BTX...
Might be better to go with a new one by the time you have the money and effort into it be about the same I would think and get a newer comp upgraded mem and such just a thougth
Sep 21, 2011 | Gateway GT4016 Desktop PC
I need the ethernet driver for the gt 4016
It should have them already on your restore partision I would go to device manager go the ethernet net card uninstall it restart the comp it should tell you it found new hardware and then tell it to look for the best driver for it
Jun 19, 2011 | Gateway GT4016 Desktop PC
Gateway 4016 will also not boot.
Certainly could...when all else fails check the case. I had an issue like this with my last computer. Turned out to be the case. A friend of mine had the same issue and his turned out to be the video card...it was drawing more power then his PS could handle. Either way it sounds like your on the right track.
Nov 19, 2009 | Gateway GT4016 Desktop PC
Gt 4016 when I finally can get the button on, the fan runs for about 15 seconds then shuts down.
May be your motherboard is defective or else cpu temperature is high. try to see it in the bios by pressing delete botton or F2 in the startup and goto to the hardware monitor.
Nov 15, 2009 | Gateway GT4016 Desktop PC
Gt 4016 will not bootup. Power is OK.
hit the key to go into setup usally f2 or del go to boot order screen and set cd rom as first boot device then try restore
Apr 07, 2009 | Gateway GT4016 Desktop PC
Gateway gt4016 problem
Check your monitor on another computer. If it is ok connect it to your bad computer. Open the CPU case and unplug all the data cables and power cables to HDD, floppy and cd/dvd. Remove keyboard and mouse. also remove pci cards if any. You didn't mention about video card. I guess it is onboard. Now put it on an see. If nothing happens blame the motherboard.
Dec 17, 2008 | Gateway GT4016 Desktop PC
Gateway GT 4016
it could be an electrical problem, but maybe not from your house. power companies sometimes have power surges that can fry a computer. if you go to any walmart and buy a surge protector, it should cure your problem, please note that there is a surge protector that offers a $10000 guarantee, so should you computer fry again turn that into that company that made it and get a new computer.
Nov 05, 2008 | Gateway GT4016 Desktop PC
Gateway GT4016 Desktop PC Logo
975 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
