Question about Sony KP-43T70 43" Rear Projection Television
I try to put the caption vision CC1, and it does not work
I don't have the remote of my sony kp-43t70, and I tried many times to put the caption vision to read every program, but it doesn't work. I push menu, I went to set up, went to caption vision: cc1, I tried all of them, from cc1..text4, and nothing happend. Can you help me please. Maybe is something else actived and is bloking the caption vision. Please help me. Amalia
    President:
  • 3,130 Answers
Is it reading or working on some channels? If it is your set is working correctly as not every channel has closed caption available on them. Good Luck
Posted on Jul 18, 2007
SOURCE:
Lamp part number
KP-43T70 is a CRT based rear projector and does not use a Lamp like newer LCD/DLP projectors. It uses 3 (Red, Green, Blue) glycol liquid cooled CRT's (like the picture tubes of yesteryear) to produce the image/light as opposed to a Lamp.
Nov 27, 2013 | Sony KP-43T70 43" Rear Projection...
I cant get the cc to come ON and ive tried all combinations with the modes, primary and Analog settings can u tell me what to put them on to get my CC to come ON
Two ways to get CC, if using a cable or sat box it should have this feature----in the menu for the TV there should be a item for captions---once you select it try CC1 which is the most common one of cc1-cc4-----if on the wrong one no cc.
If you find that menu and get it working many sets there have a setting so the captions will only appear if the sound is muted and not all the time----look for that one also.
Nov 01, 2012 | Panasonic PT-52LCX35
How do you get rid of closed caption?
Depending of what model of TV you have, the option to turn off the Closed Captioning is usually found in the MAIN MENU under the heading of AUDIO OPTIONS.
Look in the AUDIO OPTIONS menu and try to find where it says CAPTION VISION, or CC1, or CC2, or XDS, or TEXT1, or something similar for the display setting, then switch that to OFF.
Otherwise look on your remote control for a button to turn off the Closed Captioning (CC).
It may be a button called DISPLAY, and you just press that repeatedly until DISPLAY OFF appears on the screen.
If you provide the exact MODEL NUMBER for your TV next time in your question, more precise instructions can be provided in order to help you out.
Good luck.
Mar 10, 2011 | Televison & Video
HOW CAN I SET SUBTITLES USING THIS REMOTE CONTROL?
Push MENU on your remote.
Then scroll until you find SET UP.
Select CAPTION VISION to CC1.
Exit MENU.
Now push INFO or DISPLAY button on your remote until it reads CC1 ON.
That should be it, let us know if it works for you.
Jan 22, 2011 | Televison & Video
Okay, have Hitachi 1080 HD. Called several times to Customer Service but they couldnt help. Cannot get the words in English to appear on screen for hard of hearing.
Look in the tv menu for SET UP or AUDIO options.
Look for CAPTION VISION and set to CC1.
Now exit the menu screen.
Now use the INFO or DISPLAY button on the remote to activate the closed captioning.
It should say something like CC1 ON once you get it right.
That should be about it.
Note that not every single channel has closed captioning for every single show and that the words usually take a few seconds to show up on the screen when you change to a new channel.
Good luck, hope this helps. Keep us updated on your progress.
Jan 21, 2011 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
How do you install closed captions
Press the Display button on the remote several times until Caption Vision appears. See page 16 of this manual for info about Caption Vision: http://www.docs.sony.com/release/KV32S40.pdf
See page 20+ for info about Setup menu and Caption vision menu.
Sep 16, 2009 | Sony KV-32S45 32" TV
Closed captioning used to work. Disconnected TV to do some remodeling, now it doesn't show caption info. Tried selecting different menu options, i.e. CC1, CC2, etc. No luck. My TV is a Sony Wega...
You need to use a remote control to fix this one. There are options, and some say different things. but there is always a seperate button for Closed Captioning on TV's.
-hannah
Jul 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Closed caption problem with Sony Bravia KDL-46S5100
CALL SONY NUMBER SHOULD BE UNDER SUPPORT ON YOUR MENU SYSTEM MIGHT NEED SOFTWARE UPGRADE THEY CAN SEND YOU ONE SHOULD HAVE USB INTERFACE. ALSO IF YOU ARE ON CABLE TRY RESCANNING CHANNELS IF YOUR ON SATELLITE MAKE SURE CC IS IS SET ON, ON SAT REC
Apr 12, 2009 | Televison & Video
I'm getting a display of the dialogue
go into the menu for your tv or look for button that says cc or closed captioning or audio and turn closed capt off---keep trying each opt until its off if it just says cc1 cc2 cc3- cc- if have off opt just choose off..hope helps
Jan 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-43T70 green ghost problem
The cause of the problem can be that the CRT-s are getting weak. Life span of CRT is around 30000 hours of working time. Please calculate. If you need more info please advice.
Apr 03, 2007 | Sony KP-43T70 43" Rear Projection...
Sony KP-43T70 43" Rear Projection Television Logo
214 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
