Question about Bosch Dishwashers
Where is the float valve located on the ASKO D1706 dishwasher?
Dishwasher will not fill.
SOURCE: Asko D1706
I live in Australia, My one had the same problem, I found them in e-Bay.
Posted on Dec 25, 2008
appldoctom
  • 311 Answers
SOURCE: electrolux Dishwasher 24 " not
if i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
Posted on Jan 24, 2009
  • 14 Answers
SOURCE: Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Posted on Jun 18, 2009
  • 14 Answers
SOURCE: hi i have a asko dishwasher the water will not
Check this solution
Posted on Jul 08, 2009
  • 10865 Answers
SOURCE: Dishwasher always fills to float valve
There are actually several possible causes of your problem. I will briefly describe each in hopes that you can isolate the problem and will then know how to proceed.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Aug 02, 2009
Drain pump small black insert, found in the sump area. Where can I find one of these for my ASKO D1706 Dishwasher?
call asko directly, or call Great Plains Appliance Parts. Don't know the numbers, but Asko stocks parts in Texas, and Great Plains stocks them in Denver.
Aug 29, 2013 | Asko D1706 Built-in Dishwasher
Asko D1706 - filter is stuck we can't remove it...any suggestion???
Try a few drops of liquid wrench on it, wait half an hour and try turning counter clockwise again.
Jan 10, 2013 | Asko D1706 Built-in Dishwasher
Water not cycling through
Hello
This sounds like you may have either a faulty solenoid valve which controls the entry and exit of water in a dishwasher , or a faulty float which controls the level of the later
This requires a hands on tech on location to do diagnostic tests to be sure which it i
If there is a float, you will see it on the floor of the dishwasher round and sticking up.
grab it with your hand and see if it moves loosely.
BUT, if the water level is low every dishwasher will time out and stop working.
I have seen people who get a pump set up because they have a well or just have low water pressure.
The heating element may also be faulty and need replacement
Aug 09, 2011 | Asko D1706 Built-in Dishwasher
Water sounds like its comming to dishwasher after awhile dial turns(timer) disher wsher goes in to dishcharge pumping out water but inside of dish washer seems dry like no wash cycle took place
Look inside the dishwasher for large plastic mushroom-shaped thing in the bottom. This is a float. Sometimes a knife or fork or something else gets in the bottom of the dishwasher and won't let the float go down. When the float is up like this, the dishwasher thinks that it is already full of water, so no water pumps in.
If this is the case, simply remove whatever is blocking the float from going down, and it will work again.
Feb 28, 2011 | Asko D1706 Built-in Dishwasher
D1705 - NOT FILLING WITH WATER
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Oct 07, 2010 | Asko D1706 Built-in Dishwasher
No water coming through the pipes
If there's no water entering your dishwasher, check these:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Apr 12, 2010 | Asko D1706 Built-in Dishwasher
My asko D1706 dishwasher will not fill with water or drain.
it could be the float ee if detergent is causeing it to get stuck see if you can move it up and down and you may also have a clogged inlet valve or faulty valve,chec both hoses also it could be a clogged pump.
Dec 01, 2009 | Dishwashers
Asko D1706
Sep 10, 2008 | Asko D1706 Built-in Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
