Question about Electrical Supplies
Pull cord I just want to know if a pull cord on a generator can be replaced. and if so where can you buy a replacement
  • Anonymous Feb 13, 2009
    the recoil assembly of my coleman 1850 watts generator is broken, where can i buy this part?
  • 10,865 Answers
Yes. Most any hardware store can sell you a new cord. If you want to replace both the cord and the pull mechanism you may have to contact a dealer.
Posted on Jan 26, 2009
2 Suggested Answers
  • 342 Answers
SOURCE: I broke the pull cord on my generator; how do I
you should remove the housing usually 4 bolts
dont remove anything else then look at the pully and remove the old chord tie a knot in the new chord and slot it into the hole on the pulley
you should then see a notch in the edge of the pulley this is for the chord to sit in while you turn the pully enough times to tension the recoil spring once tensioned enough so that it recoils all the chord slot the chord through the hole in the outer casing through the pull hande and knot it job done then refit
Posted on May 10, 2010
How do I replace the pull cord on my maxa 3000 Coleman generator?
Pull cord repair is pretty generic. There are lots of videos on YouTube if this one doesn't help.
HOW TO Generator Pull Cord Repair
Sep 09, 2017 | Coleman Electrical Supplies
How do u get into the pull cord assembly to fix the cord to the coul
Hi Martha,here's the type of lawnmower I have,it's a video showing you how to replace your rope,if not your type of mower,let me know what type and hopefully I can find you a video,it's real simple.I bought my mower from Lowe's. Small Engine Repair Replacing the Starter Pull Cord on Briggs Stratton...
Aug 02, 2015 | Electrical Supplies
How to replace starter cord
buy about 2 meters of rope,and disassembly the round cover at starter cord.pull out all the rope and change it makin roll it again inside the wheel holding it.
assembly.
Sep 02, 2014 | Electrical Supplies
My pull cord broke. Is this something I can do or do I have to find a service person. By the way, I am a hurricane victim without power for at least a week. No service person is even accepting calls.
Hi Jimmy,
Here's a link to a YouTube video on replacing a starter rope. It might not be exactly the same as your generator but gives you an idea of what you have to do:
http://www.youtube.com/watch?v=8jKwGZ5w7dY
If you search in YouTube for "replacing pull cord + generator" you will find more videos.
Hope this helps!
Aug 29, 2011 | Briggs & Stratton Power Products 5,550...
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
Hi . My pull cord has just snapped. I plan to buy another replacement cord. Do i just replace the cord or do i have to re tension anything ? Thanks
You have to wind the coiled spring thing before you connect the new rope to it so that it will rewind when you're cranking. It can be tricky and an extra pair of hands will come in handy. Remove the engine cover and turn it over to access the rewind mechanism.
Apr 06, 2010 | Master Heaters MASTER HONDA POWERED...
Recoil starter spring has unwound Briggs & Stratton 4 HP mower motor
you can buy the whole recoil + pull cord ready to install ,or have a small engine shop rewind it if you cant. some times the tab that held it breaks and you have to replace it.
Mar 06, 2010 | Briggs & Stratton Power Products 5,550...
Honda 2000i generator need to replace power pull cord
take of cover where cord goes in watch direction and replace cord. wind up spring in right direction, test and replace cover.
Dec 09, 2009 | Electrical Supplies
Generater run with low oil,cant pull starter cord more than a couple of inchs,I think the motor is locked can it be repaired
Probably, but you just can't know till the engine is torn down for inspection. Will have to replace the rod, possibly the crank. Look also for damage to piston & cylinder wall. You might be better off with replacement engine.
Jun 24, 2009 | Electrical Supplies
Electrical Supplies Logo
1,323 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
