Can my tv play videos/media from a small external hard drive via USB cable? I've used USB memory sticks no problem (64gb Sandisk) - wondering if an external hard drive will draw too much power/amps thru the tv's USB. My hdd is a Intenso 320GB 2.5" small external,powered thru single usb cable.
"Wondering if an external hard drive will draw too much power/amps thru the TV's USB."
Yes, it probably would, so you are better off using a self-powered (one that you plug in to a wall outlet) drive.
And even if you got it running, it might crash halfway through a movie or something. But, for sheets & giggles, if you have all of the data that is on the 2.5" backed up somewhere else, give the 2.5" a try.
Good luck.
SOURCE: wharfedale DVD1100 PLayer does not detect USB Hard drive
I'm sure you probably have done this but i gotta ask!
When using usb there's enough power to run the usb key. When using 2.5inch hard drive the usb has enough power to run it. When using a 500gig you will need a separate powersource for it so check to make sure thats the case.
Also, a lot of these dvds will will only work with ide external harddrives and not sata external ones so make sure you use ide drives only.
good luck
smeags.
SOURCE: Is my LaCie External USB 2.0 500GB fried/dead???
Does it make any clicking/clunking sounds like any of these?
If yes - it's really bad and there's nothing you could by yourself..
If it sounds normal or doesn't spin up at all then try to remove it from enclosure and connect directly to a PC.
SOURCE: New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
SOURCE: Removal of boot.com virus from external hard drive and USB Stick
Silakan baca di >sini<
Desi Vibes
"boot.com"
is a virus which attacks the hard drives & the hard drives could
not be opened by double clicking. In hard drives after enabling viewing
hidden file u can see some "autorun" file & a file named "boot.com"
which cannot be removed just by deleting.
Here’s the REAL way to clean this off your system. You should do these steps after a fresh reboot in safe mode.
1) Navigate to the problem drive(s) via the Explore option.
2) Click on TOOLS -> FOLDER OPTIONS
3) Click the button which says ‘Show hidden files and folders.
4) UNCHECK the following boxes:
Hide extensions for known file types
Hide protected operrating system files
5) Find and delete the autorun.ini file and the resycled folder on the root directory of all affected drives.
6) Check “c:\windows\system32\dllcache” for boot.com file and delete it if present.
7) Check “c:\windows\prefetch” for boot.com file and delete if present.
8) Delete all files from c:\windows\temp
(Some files may not delete, that’s ok, they’re in use by the system and not virus files.)
9) Delete all files from c:\Documents and Settings\[USER PROFILE]\Local Settings\Temp
(Again, a couple files may not delete, don’t worry.)
10) Run Regedit
11) Make sure you are at the very first entry of the registry hive. (My Computer should be hilighted) then click EDIT -> FIND
12) Search for “boot.com”. If it finds an entry, delete it. Keep
hitting F3 until you’ve deleted all instances of boot.com in the entire
registry.
13) Scroll the left column back up to the top and hilight the My Computer again at the top of the registry hive.
14) Click Edit -> Find again and search for ‘resycled’ and repeat as in step 13, deleting the entries as it finds them.
15) Close registry editor and try opening the infected drives. They should work now.
Worked for me at least.
SOURCE: SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
