Question about Electrical Supplies
Wall Lights I want to fix wall lights to a wall where the back of it is in the garage.So to save channeling cables and redecorating I intend to drill through the wall and wire up in the garage.The problem I have,is the only accessible source is a spurred ring main socket. Can I just plug my wall light wiring into the socket,fused at say 5amp.
  • 2 more comments
  • restcote Jan 26, 2009
    Couldn't I just plug into the socket just like I would a table light.
    Thank You,most helpful.
  • restcote Jan 29, 2009
    Hi Justaskjoe,I realised that I did have a socket in the garage that was on the ring main,so I have connected up as follows:----
    1.Fitted a 13amp Fused Circuit Unit as a Spur to the Ring Main socket.
    2.Fitted a 13amp 4way junction box from the FCU.Live to 1,N to 4 and E to 3
    3.Fitted a On/Off Switch to Junction Box.Live to 1,N(return live) to 2 and E to 3.
    4.Fitted Wall Lights to Junction Box.Live to 2,N to 4 and E to 3.
    Switched Power back on,all units on ring main came on.Switched on FCU and neon lit up and finally switched on Wall Lights,they started to flicker on and off for a few seconds. I switched them off and on a couple of times and they now seem to be alright.
    Is this normal????
    Again thanks for your help.
  • 10,865 Answers
Only one socket outlet can be connected to a spur. (This can be a single or double outlet). Connecting a further outlet is NOT permitted, as this could overload the single cable supplying it. Each socket outlet or junction box on the ring can only have one spur connected. Trying to connect two or more is not only very difficult due to the number of wires involved, it can also result in an abnormally high load at that point in the ring.
The number of spurs on the ring must not exceed the number of other socket outlets. If for some reason you need a large number of spurs, it is time to replace the whole circuit rather than keep adding to it.
The only safe way to do this is to run a new circuit from your panel. good luck
Posted on Jan 26, 2009
  • 2 more comments
  • Joe Hogan Jan 26, 2009
    Technically you should determine how many other devices are using this circuit and how large the circuit is. For example if it is a 15 amp circuit it can handle up to 1500 watts, and a 20 amp circuit can handle 2000 watts. If your circuit is current underutilized you can proceed.
    You are most welcome I assure u.
  • Joe Hogan Jan 29, 2009
    Based upon what you have stated here it sounds like you are protected as long as you have everything fused the way you do. Enjoy your lights.
  • Joe Hogan Feb 01, 2009
    You are welcome.
My remotes work but the one on the garage wall does not tell time or temp or open the door anymore. are there batteries also it does not light up anymore garage door openers were not listed. thanks
We came back from vacation and my wall unit garage door opener on the wall light was off and does not work.How do I fix it??Thank you
May 09, 2011 | GPS
Tip
Fix Up That Old Fixer Upper With These Garage Door Tips
<br><br>As a way to boost the curb appeal of your property, paint the garage door. Because <a href="http://www.garage-door-experts-bonita.com" target="_blank">Bonita garage doors</a> are constantly exposed to rain, sun and changing temperatures, they may appear worn or grungy. A splash of new paint will rejuvenate the style of all of your house, and add value at the same time. As opposed to choosing something ordinary, paint your garage door an excellent color to compliment your property.<br><br>Getting redecorating work done, having a minimum of fuss is a worthy goal. Repairs and maintenance really are a basic requirement of home ownership. Building a home more livable and more valuable is readily possible for homeowners who happen to be prepared to put in work above and beyond these minimum necessities. You, too will have a better looking home in the event you keep using redecorating.<br><br>Many individuals wish to give redecorating a shot, but frequently it turns out to be to difficult so they can perform properly plus they stop trying. Should you be built with the best information, redecorating is easy. Utilize the advice provided here once you try your hands in your house improvement.<br><br>Before you decide to commit to a different paint color for the exterior of your home, take some time driving around and seeking at homes which you like the style and color scheme of. Paint chips are extremely hard to envision, so seeing it directly may help you make a better decision.<br><br>With regards to redecorating, the smallest bidder for your personal project is not going to always translate being the individual who does the ideal work. Many times, an estimate which is too good to be real is simply that, because of poor work quality or hidden costs. Make sure you check with any agencies that provide feedback about contractors prior to hiring them. <a href="http://www.garage-door-experts-bonita.com" target="_blank">garage doors Bonita</a><br><br>Should you don't need to have a toilet that won't stop running, try checking the flapper valve. Flapper valves act as rubber seals for the tank and permit water inside and outside. Pull the siphon through the tank and examine the valve. If it's dirty, clean it. Whether its broken, replace the valve with a new one.<br><br>Substituting vinyl tiles for stone or ceramic ones is ways to save a lot of money when you're installing a brand new floor surface. Vinyl is very durable and powerful. It is actually proof against water and straightforward to set in. Vinyl flooring is bought in tile sets or perhaps in a sheet useful for larger areas.<br><br>You can make simple art for your personal wall by buying some solid colored picture frames and tearing out pictures from old children's books. Illustrations through the likes of Alice in Wonderland, Wizard of Oz and so forth are really popular. They are great old fashioned wall art, and add a little personality to your residence.<br><br>Anyone who owns a house can fix their very own faucets which leak. If you can repair and fix these quickly, it is possible to conserve water instead of waste money. The savings alone will add up quite nicely in the event you tackle this challenge immediately.<br><br>When contemplating what redecorating project to accomplish, avoid home repairs unless they may be absolutely necessary. Such things as painting the inside or exterior of your home have zero impact on the need for your residence. Spend your time on other projects that provides you with a much better return for the money you may spend.<br><br>If you would like your living room or dorm to get a contemporary clean feel with it, choose to get a sofa with minimal cushioning and long, lean lines. Opt for the sofa in the bold color such as black, red, or beige to create a statement in your area. You are able to dress it with some zebra print or striped decorative pillows.<br><br>Balance the design of your respective living room by arranging your furniture symmetrically. For instance, opt to put your couch as a center of attention, a coffee table in the center as well as two lounge chairs in the opposite side of the couch-one on each side. Symmetry can even be achieved in your bedroom, by placing matching lamps and nightstands, on both sides of your respective bed.
on Aug 04, 2013 | Safe International New and Improved HOME...
I have a motion detector console which does turn the lights on the garage door opener when it senses motion, but it fails to turn it off from time to time once I've left the garage. I've replaced the...
The wires going to the wall control are color coded. One of them is white and the other is white with a red stripe. Make sure they are attached to the correct terminals at the motor unit and on the back of the wall control.
Oct 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will open with remotes, but not with the wall switch
Sure sounds like the wall control is bad. Very common problem.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wall Lights from outside
Normally it is not allowable to run a regular cable (such as a Romex) where it will be exposed. Which it sounds like this cable will be run. Your best bet to make it a legal and safe install is to use a metal clad, or armored type cable (called MC, BX, or "greenfield" by some).
Jan 30, 2009 | Electrical Supplies
Is my FS605 broken
The FS06 switch is probably defective and needs to be replaced...especially if the status of the lights does not change after you cycle the power on and off with no network cables plugged in. These switches are sensitive to overheating and can easily be damaged if used next to other warm network equipment or with air vents blocked by papers, etc.
Turn-on order is not critical in this scenario, but ideally you should plug in all network cables, turn on the switch first, then turn on the computer.
Jan 10, 2008 | NetGear FS605 (FS605SE) Networking Switch
Electrical Supplies Logo
196 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
