Question about Samsung HP-R4252 42 in. Plasma HDTV
Samsung ps-50q96hdx/xeu hi there i have a 50 inch plasma tv model ps-50q96hdx/xeu the picture and sound are fine apart from a 4 inch bar with lines in it half way down can this be easily fixed
  • 4 more comments
  • benny1951 Jan 26, 2009
    the ic on the board so which board is that on the y the x or the lower y or upper y board
    hi there looking at the back of the tv would these cables be on the left or the right would a loose cable cause the 4 inch bar with lines in
    hi there i would like repair this myself but if it is the ic which board is it on and how much roughly would it cost as tv men charge a fortune
    hi there am just using standard tv its not connected to anything
    so it dont involve changing a board then i thought it was a minor fault on the lower y drive board
  • benny1951 Jan 27, 2009
    hi there so whats $100 dollors in english money so its really a job for a tv repair man then
  • Samsung Master
  • 19,396 Answers
When you get a "4 inch bar with lines in it half way down" it is always a buffer board, if it starts from bottom it is lower buffer, otherwise upper buffer (note: Y Sus and Low/high Y buffer are differnet boards.
In UK minimum charge for replacement is 50 pounds, usual charge for testing boards and replacing is 80 pounds labour plus board price that is 50/60 pounds.
Here is an example of low buf for a similar model.
Posted on Jan 27, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! After reading the Previous Posts, The Repair shop is this TV's only hope at this point and 100.00 is a Small Price to keep a Good TV. Please Rate my Response, I need all the Help That I can Get! Thanks!
    Genius:
  • 2,920 Answers
You need to send it to a repair shop and have it fixed...it could be any number of things wrong with it that needs fixed and it would be safer and wiser to send it in for repair
Posted on Jan 26, 2009
    Sergeant:
    Scholar:
  • 199 Answers
Http://hdguru.com/?p=127
just click this link anbd get the exact information with diagrams. thanks,
    Scholar:
  • 160 Answers
You can try first to zoom the screen by pressing the zoom button option as it can be not set on proper required mode.this can also be the cause of this.either it can be faulty component can cause you near to $100 for getting it repaired.as it has to be checked with a meter on which board the faulty component located.and u can get the required parts at  www.radioshack.com
    Sergeant:
  • 378 Answers
What connection are you using when you get this bar? Have you tried another connection to see if you still get the bar? For example, if you're using the PJs component video connection, try using the HDMI port or vice-versa.
push the menu button on the box and the service menu will come up. use the curser buttons to select HDMI settings. change the color type form 4:4:4 to RGB then push menu, then turn the set back on.
check your composite video cable (Red, Blue, Green) and make sure both ends are securley inserted.
remove and reattach the cables again.
  • 11,896 Answers
Screen controls need adjustment or your vertical caps or vertical IC could be bad.....
the screen can be adjusted by removing that back of the tv and finding the knobs, otherwise you will have to have an electroics tech fix
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Jan 26, 2009
    The bar is there because that section of the
    grid is either not receiving information from the processor or is
    unable to display that data it's receiving.
  • Nate Stansfield
    If you want to get it fixed it will likely cost $100-200 or so. TV
    repair rates have actually come down a bit lately, since there is so
    much push to just junk old TVs and buy new TVs with digital tuners.
    Some repair shops have lowered their rates to try to make "repair and
    keep" a more attractive option.
    Do not operate the set with the picture like that. If left for too long
    it will burn into the screen, and then after repair the screen will
    forever have a dark region where that bar used to be.
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    If you like to and feel comfortable doing so, you can remove the back of the tv and try adjusting the v-hold and other picture adjusting screws. It is worth a try, but it if this doesn't correct the problem, then you will have to replace the vertical caps or veritical IC
  • 130 Answers
Call 1-800-726-7864 -- that is samsungs tech number
    Brigadier General:
  • 8,619 Answers
Hi!
Check your composite video cable (Red, Blue, Green) and make sure both ends are securley inserted
    Sergeant:
  • 221 Answers
Its the problem of ic on the board that is at its last stage its got weak or maY be got loose internally.technical help is much advisable.yes its worth fixing.a common problem easily gets resolved.
Samsung 50 inch PLASMA TV PS-50Q91HD with no picture. TV turns on but no picture. Sound is fine.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.....
Nov 16, 2016 | Samsung Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Have a 50 Samsung plasma that has developed vertical white lines across the screen about 1 inch apart. Quality of picture is still great and unaffected. Lines have left once or twice but come back. Ca
Maybe it's time 4 a new t.v. Do you leave t.v. on a lot or play a lot games. Turn off your t.v. when not using. Is t.v. old, get a new new one. You will be you did. The newer sets have HD which make for better viewing. I suggest an LED and not a Plasma.
Jan 28, 2015 | Samsung PN50B450B1DXZA - 50in Ws Plasma Tv...
Best picture settings for samsung ps50a457p1d
my 50 inch samsung is 4 years old. a black line has appeared just off centre screen. the line is approx.an inch wide and runs from top to bottom. can it be repaired?
Mar 08, 2012 | Samsung PS50A457 50 in. Plasma TV
Hi there i have a 50 inch plasma tv model ps-50q96hdx/xeu which seems to have a mind of it's own when i switch it on. sometimes it comes on, sometimes it won't! when it does turn on it has been found
You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits.
The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced.
The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off.
This is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
You know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.
You still need to check for leakages...
Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck.
Nov 09, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Nov 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
416 people viewed this question
Henry  Thomas
Henry Thomas
