Question about Jenn-Air W30400P Stainless Steel Electric Single Oven
Cut in size for W30400P - Jenn-Air W30400P Stainless Steel Electric Single Oven
Can NOT remove glass cover to change light in oven Jenn Air W30400P
If it is the round glass cover it should unscrew. It is thick glass so you might need to try more force of tap it with a piece of wood.
Jan 02, 2011 | Ovens
Can NOT get cover off to replace bulb in oven
Assume it is the round glass cover.
It is quite robust so use more pressure. Even tal with a piece of wood.
Jan 02, 2011 | Jenn-Air W30400P Stainless Steel Electric...
The self cleaning oven is not working. The fan in the back of the oven turns very slowly. the door locks briefly and then unlocks and everything shuts off.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Jenn-Air W30400P Stainless Steel Electric...
When I start the self cleaning cycle After about 15 minutes it starts beeping and the display shows F5. The unit is about 10yrs old. What could this be?
This could a bad temperature sensor or a bad clock.(ERC).
Disconnect the power.
Remove the rear panel.
Unhook the temperature sensor wire and test the temp sensor with a volt/ohm meter set for ohms.
A plus/minus reading of 1100 ohms is good.
If temp sensor reads good replace the ERC(clock).
Nov 28, 2010 | Jenn-Air W30400P Stainless Steel Electric...
Display light
Found out that I could replace the C3 capacitor with a 100uF 35V (high temperature - 105 C). Spent $1.69 for the capacitor and 1/2 hour taking the unit out, soldering the new capacitor in, and remounting the upper clock unit back on the oven. Works like a charm. No need to buy the whole Clock/Temp unit, waste of money.
Aug 13, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Jenn Air oven
Does anyone know the part number to replace on model W30400P - the digital display is completely out - the oven heats up but can't read time/temp - not a thing on the LED display - thanks!
Nov 19, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn -air oven w30400p
Do you mean the service engineer replaced the hinges?
If so call him again and tell him he didn't fix it. The service engineer should come again and fix it for free if there's any justice in this world.
Nov 08, 2007 | Jenn-Air W30400P Stainless Steel Electric...
JennAir W30400P
i think you can get downloads from maytag.
Mar 25, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air W30400P Stainless Steel Electric Single Oven Logo
22 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
