My scan disk flash malfunctions - Computers & Internet
  • 1 more comment
  • donshege Jan 27, 2009
    i got the flash drive newly and i activated it security, after a while a could not access the information on it except on the PC where i activate the password,so i had to remove the password.
    Just on this last thursday,i activated the security code on one of the laptops i used, after sometime i tried using it unfortunately, it was not accessible the PC only says the flash is not accessible and malfunction, i used it on the PC where i activated the security it was giving me similar prob. even try to see if it can be formatted but it was just not accessible.
    Thank you
  • megax01
    megax01 May 11, 2010
    Can you give me more information on the flash drive itself.
    Who made it?
    What Brand is it?
    Whats its model number?
    and how much memory it has?
    Also what is the security program that you used to lock it?
  • megax01
    Malfunctions in what way? Does it lose data? Does it refuse to load? Are u unable to save? How exactly does it malfunction?
  • 30 Answers
D possible reasons r , u may unplugged while its processing or formatting. If so u cant do any thing with it. If u have warranty ask them to replace
Posted on Sep 21, 2009
Server disk full in bizhub 420
malfunction was detected cs remote care c2403
Aug 21, 2012 | Konica Minolta bizhub 420
My transcend pendrive dispalys 0 bytes . how to overcome that come
Try to run a scan-disk.
Right click on the drive's icon in my computer, select properties. Go to tools tab and select "check now".
Depending on your operating system this might be called either scan disk, check disk or "check volume for errors".
Jan 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
1gb
in my pen dirve Scan disk U3 its showing 2 dirvers its showing f:/ Removable disk and also H:/ also removable disk
what to do.
it showing in scan disk
Oct 03, 2010 | SanDisk 1GB Cruzer Titanium USB Flash...
I am not recognising kigston data traveller
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
NOTE Formating the USB flash drive will delete your data.
May 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
What does it mean when the D for drive flashes on the gear indicator
That indicates a malfunction in the transmission. The computer will have to be scanned to determine what is malfunctioning.
May 11, 2010 | 2005 Honda Pilot
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Genx 4gb flash disk problem
the most defalt of option is reinstal the driver and check in the Device Manager the usb you  have 3 usb root hub,1 enhanced pci to usb controler,update and try again,it should work.
Oct 31, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
No access to USB drive when inserted (Windows). ''Malfunction'' error message.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 30, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Kingston U3 Flash Drive malfunctioning
. have you tried the Flash on another PC?? if it's the same error you get, i am afraid you Flash has a Malfunction. The only option is to format the device & use a Data recovery software to recover the data on the disk. but this is not guaranteed as there is a chance of you loosing some data as well the recovery cost
Mar 19, 2009 | Computers & Internet
SanDisk Malfunction
unfortunately the files cannot be recovered immediately, macs a are compatible with PC flash drives but not the other way around. you need to format the disk. go to start>my computer> then right click on the flash drive and then left click on format, then click ok. when it is done bring the flash drive back to the mac and put the files back on. now try putting the flash drive into the pc again
Jan 23, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
