Question about Tasco 750 Monocular Microscope
Need bulb for tasco super-lite - Tasco 750 Monocular Microscope
LED LIGHT REPLACEMENT ON A LAREDO 308RE
In most models the light lens just pops out when the lens is squeezed to access the light bulb.
Aug 11, 2016 | Keystone 2012 Laredo Super Lite 308RE
How do find a replacemnt bulb for this tasco 750 x zoom microscope?
contact tasco.
try ebay for a month (search various combinations of keywords). notify by email.
21.january.2015
Aug 02, 2014 | Tasco 750 Monocular Microscope
No brake lights where do i find fuse box on 1982 1340 fxr
Hi Anonymous, there are no fuses just a couple of circuit breakers behind the left side panel. Check your tailite bulb first, then grab a test lite and check for continuity at the front and rear brake lite switch, also check the wiring underneath the rear fender. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 19, 2014 | 2003 Harley Davidson FXD Dyna Super Glide
2001 f-250 brakes lites don't work. fuses good and installed new pedel switch still no brake lites
Could be as simple as bulbs died. Second I would check if lights have good grounding (these things tend to corrode over time. Usually black wire and have connection to vehicle's chassis). Or could be broken wire/shorted wire.
Nov 06, 2013 | Motorcraft 2001 Ford F-250 Super Duty Fuel...
2008 ford f250: rear passenger brake,tail and blinker not working. the front blinker and side marker light on mirror works. dash blinker is blinking very fast
could be the tail lite housing. or the ground on the frame rail back near that location. remove the assembly till its hanging by its wires and remove the bulb. using a test lite probe the socket with the flasher on see if it blinks. if not go down under the rear of the truck and unplug the connector for both tail lites and do the same probe each connector on the harness that goes forward till your test lite starts to blink if it does there then the tail lite assembly is bad if not then repost and ill lead you further
Jan 20, 2011 | 2008 Ford F 250 Super Duty 4WD
Where can I buy the light bulb for a 1200 zoom microscope in the state of Indiana
Microscope bulbs can be hard to find at a local hardware or electrical store in you area. The best, and cheapest solution is to go to http://www/bulbtronics.com. You will need to know the specification of the bulb in you are to buy online, but if not, their customer service folks are very good at helping you determine what those specifications are, and what bulb you will need to purchase.
Dec 22, 2010 | Tasco Science & Laboratory
I picked up an tasco 1200x from yard sale, the set didn't come with a manual and I need help working it. When I look in it I cant see anything. also I can't get light to cme on. Also the kit come with...
All of Tasco's manuals are located here:
http://www.tasco.com/pages/instruction-manuals/
Put the eyepiece with the largest number written on it into the focuser. Do NOT use the 2x barlow if you have one. Take it outside during the day time and practice focusing on a distant object.
My advice is NEVER buy a telescope at a yard sale unless you know exactly what you are buying.
Oct 21, 2010 | Tasco Optics
I need a replacement bulb for my tasco 1200 zoom microscope kit. Where can I purchase one?
If you have a manual for the kit it may have a parts list. The bulb may have a part number on it , or the bulbs rating such as 2.5 Volts / 270 ma. Radio Shack should be able to help you. Just remove the bulb or take the unit with you to the store. The bulb is probably less than $2.
Aug 18, 2010 | Science & Laboratory
2001 Ford F250 4x4 Rear lights won't work
the cause for a blown fuse is a short circut or over load remove the bulb turn light on with new fuse if the fuse blows then you have a short somewhere in th wire trace wire down till you find the short then repair with a **** connector replace fuse turn light on that should take care of your problem & if the fuse dosen't blow with the bulb out replace the bulb
Jun 03, 2009 | 2001 Ford F250 Super Duty Super Cab
Tasco 750 Monocular Microscope Logo
87 people viewed this question
Top Tasco Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Tasco Science and Laboratory Expert? Answer questions, earn points and help others
