Question about Kenmore 63942 Dryer
Kenmore Dryer shuts off to soon.
Dryer cuts off before clothes are dry. Indicator light is still on. I have to wait for dryer to cool down before it will start up again.
  • Kenmore Master
  • 8,220 Answers
Might be something lugging down the motor causing it to shut down on overload. Too many clothes,bad rollers, idler, or slides. All can cause the motor to have fits. It might just be time to replace the motor or try and oil it. They don't put any oil holes for the bearings. You must make some. Use high temp oil to fill the bearing wells. Work the motor free. If you are gonna replace the motor remember the blower wheel has backwards threads.
Posted on Feb 07, 2009
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
I have a Kenmore 80 Series Gas Dryer. We replaced the motor and blower wheel in October of 2010. Recently the the dryer has been stopping while drying clothes. No matter what cycle I put it on, it almost...
Hi, In looking at your problem please do the following. Go behind the dryer. The vent hose that is attached to the back of the dryer has to go straight to the wall outlet. It must not have any bends whatsoever. Its a straight shot to the wall. This should take care of it shutting off and being too hot. You may need, after the above, to change out the cycling thermo. Thanks for your inquiry and hope this helps. Have a Good Day!
Jan 18, 2011 | Dryers
Stops before clothes are dry
Sounds like a motor going out . You need to replace the motor .
Jun 29, 2010 | Kenmore 65924 Electric Dryer
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
96 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
