Question about Frigidaire PLEFMZ99EC Electric Kitchen Range
Warming zone knob won't turn - Frigidaire PLEFMZ99EC Electric Kitchen Range
Element won't turn off
Bad control knob? Hard to say with out more info. To check if it is your control knob, you can unplug the stove, switch the wires from the nearest control with the one you are having problems with and then plug it back in. If you are now having the problem with a different element, then you can pretty much be certain its in the controls. Hope this helps.
Feb 06, 2013 | KitchenAid Kitchen Ranges
Won't heat my studio - even on "HIGH"
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
Jan 01, 2013 | Comfort Zone CZ7007 Oil Filled Electric...
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
My Kenmore 600 series dryer won't start when I push the start knob...I can hear a hum when the knob is pushed in but it won't start. Any suggestions?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
'lll
Aug 17, 2011 | Dryers
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
How to remove spool from cap on a reflex plus strimmer
Usually these trimmer spools are retained with a threaded 'knob' with serrated edges. The problem usually is that the knob won't turn - or so it seems. You will have to hold the spool itself while attempting to turn the knob off - turn the knob counter-clockwise!! Remember - righty tighty, lefty loosie! I usually need to turn the knob with a large pair of alligator pliers to get its grip broken, then I can turn it off by hand. Good luck with it!
Jun 21, 2011 | Black & Decker Garden
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
It won't start. Turning the knob, I don't hear the
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 06, 2011 | Dehumidifiers
Frigidaire PLEFMZ99EC Electric Kitchen Range Logo
35 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
