Question about Greenlee 7646 Hydraulic Punch Driver
G-Lee 767A leaks out of the bottom hole when I attempt to punch
When we start to put pressure on metal we what to /punchcut, fluid leaks out of the bottom cap with the hole in it.
Thanks,
Mike
PS, Could NOT find 767A punch in products below. Can you still help?
Mike
2 "u" cup seals need to be changed in the reserve tube
Posted on May 24, 2009
Holes missing from 5 tier bookcase metal Putting shelves together. Can I drill Holes in metal?
Yes you can, you just need a drill, the correct size SHARP drill bit, a pin punch - important!! - (to punch a dent in the exact place you want the hole to be - this will hold the drill bit in place when you start drilling)..take you time..use a piece of wood (2x4) to back up the piece your are drilling into... then deburr with a file..
Jul 02, 2017 | Drills
2005 Harley Davidson FXDL - FXDLI brake will not pump up
Hi mcknightmr, start by turning the front wheel all the way to the left and position the master cylinder and handle bars if necessary so that the top of the fluid bowl is parallel to the floor. If you have the brake line off the master cylinder make sure its full of Dot 5 and try priming it by putting a finger over the brake line hole and quickly tap the handle and release your finger to expell the air. Do this untill you see a geizer of fluid shoot straight up from the fluid bowl. Then attach the brake line and the clear plastic bleed line. This next procedure requires you to keep the bowl full at all times, never let the bypass holes at the bottom become exposed to air. Open the bleeder valve at the caliper a full turn and let the air and fluid run out untill you see no more bubbles. Close bleeder valve and check handle for pressure. If you can't get a solid pressurized lever after three attempts, you have to take it to your local dealer or shop and have it pressure bled. good luck
Aug 24, 2012 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
My keurig won't punch a hole in the bottom of the kcup amd the water comes out squirting everywhere not in a stream
I had the same problem after 3 day's use. I discovered the metal punch was flattened. I used a pliers to bend it gently back up and it worked for a while. It quit again so I'm returning it. Meanwhile, I punch a hole on the bottom of the k-cup and line it up at the top when I insert it. It works that way.
May 02, 2011 | Microwave Ovens
I have a 2007 Town & Country that leaks power steering fluid from what seems like the bottom of the car. It sounds like fluid is coming from a hose but I'm not sure which hose. Can it be the pressure...
depending on the options of the vehicle you have a pressure and return line that goes from pump to steering rack. some have a fluid cooler. but most likely it is the pressure line that is leaking. they use rubber and metal lines together. bad hose clamp, rusted line, or hole in rubber line.
Feb 22, 2011 | 2007 Chrysler Town & Country LX New Cars
1994 4 Liter leaks radiator fluid from one of four metal plugs located on the engine block under the intake manifold. How do you fix?
Yes, if you can punch a hole in the leaking 'freeze plug' and get another one of the same size and tap it in, then you can fix it with the engine in the vehicle. If you can find a 'rubber stopper' that screws down and expands to fit in the freeze plug hole, that work as well. Check with your local auto parts store for these products.
Jan 14, 2011 | 1994 Jeep Wrangler
Leaking radiator/water fluid from my intake manifold close by the tensioner.
Check the bolts, are they tight? Some bolt holes are through the metal and into the void where the coolant is, if loose, when the pressure builds it will leak fluid.
Dec 27, 2010 | Buick LeSabre Cars & Trucks
Transmission leaking out the holes in the bottom of the transmission when running truck was being operated and i was told that it was not operating normal so checked the tranny and added fluid about 2...
Your pump seal is leaking and is causing you to lose pressure and fluid. Do not drive it! You will burn up the clutches as the pressure with be low and will not fully apply the clutches. Transmision must be pulled to replace.
Oct 17, 2010 | 1994 Chevrolet C1500
Greenlee 7646 Hydraulic Punch Driver Logo
384 people viewed this question
Top Greenlee Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Greenlee Home Fencing Expert? Answer questions, earn points and help others
