Question about Sylvania LC220SS1 22 in. LCD TV
Sylvania Lc 220 sl1 wont turn on - Sylvania LC220SS1 22 in. LCD TV
My tv wont come back on
Check the power cord to the television if you are unable to turn it on with the "Power" button on the front. Make sure the cord is connected properly to the television and to a working AC outlet. If a power outage has occurred, unplug the television for 30 minutes to allow it to reset and plug it back in.
Feb 01, 2013 | Sylvania LC-225SL9 22 in. LCD TV
Sylvania model lc225sl9 turns off and back on by itself
suspect either power supply or main board which controls everything--voltage and other tests would have to be made first.
Jun 12, 2012 | Sylvania LC-225SL9 22 in. LCD TV
I need a universal remote control code
get the manual.
http://tv.manualsonline.com/manuals/mfg/osram_sylvania/lc427ssx.html
If this helped vote me happy
AndystUK
Sep 02, 2009 | Sylvania LC-225SL9 22 in. LCD TV
Sylvania GNET28001SO Meso 8.9" Netbook PC (1.6 GHz Intel Atom
If you are attempting to connect your laptop between 110 and 220 volt power outlets, you may be able to do so already, take a look at your power cord's transformer (brick) and read the input voltage. If you only can use 110 volt AC Input Voltage should read 115VAC. If you can do both, then it should read 110-225VAC.
If your power brick supports 220, then all you will likely need is a plug adaptor, found at many electronics store. If not, you wil need to stop in at a computer store or an import store and get an international transformer, which are set up to convert many different country plugs and many common voltages.
Good Luck!
May 06, 2009 | Sylvania Meso GNET28001SO Notebook
Sylvania LC220SS1 22 in. LCD TV Logo
59 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
