Question about Maytag EPIC MFW9700S Front Load Washer
My maytag epic z is leaking from underneath
It wasn't alot of water, just enough to run under the washer and the dryer but not flood the laundry room
    Sergeant:
  • 291 Answers
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
Posted on Jan 21, 2013
  • brandon meeks Sep 10, 2013
    my epic z is leaking from on the back side of that concrete bloock looking like thing is there a seal between that and the drum
SOURCE: Maytag Ensignia Washer Leaks
replace the pump pump is leaking
Posted on Apr 16, 2009
BIKER T
  • 909 Answers
SOURCE: Maytag Epic Z front loading washer spin cycle very loud
your bearings and seal need to be replaced.
Posted on Sep 21, 2009
  • 105 Answers
SOURCE: I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Posted on Feb 01, 2010
  • 57 Answers
SOURCE: maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Posted on Feb 17, 2010
jsrock516
  • 5911 Answers
SOURCE: Seal is ripped
Yes, the door seal (bellow) can be purchased and replaced. The following link explains step-by-step how to change the door bellow on a Maytag Epic front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The firsat three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful. NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions will apply.
Posted on Apr 30, 2010
Testimonial: "Thanks so much for your help!"
Is it common for this appliance to leak?
if it holds water then eventually it will leak .nothing lasts forever .
Jan 08, 2016 | Maytag Epic Z and Performance Series 2000...
Kenmore washer Model A107 is pouring water out from underneath
More then likely it is the dis-charge water from pump hose. But if ya got a new machine why not!
Feb 16, 2013 | Washing Machines
I have a slow drip at the bottom of my front load washer door (Maytag Epic Z). It leaks through the bottom of the door and drips down the front of the washer onto the floor. Has done it since I bought it...
Yes the seal might need replacing. but in my experience a simple strand of hair caught on the seal will make it leak. So i suggest that you try thoroughly cleaning the seal fist. If its needs to replaced, its not that difficult, but its kind of tricky. Check if your machine is still under warranty by contacting the manufacturer. hopefully it is and they will change for you for free. If its not under warranty let me know and i'll try my best to give you detailed instructions on how to change it.
Feb 06, 2011 | Maytag Epic 7.0 Cu. Ft. Super Capacity...
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
My water continues to run in the washer even when the washer is off and causing my room to flood
The switch that the water hoses are connected to is stuck in the open position. it can be removed and cleaned by taking it apart or just replace it
Nov 08, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water Leak from the Front Door of our Maytag Epic MFW9700S
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
Jan 28, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water is coming out from underneath my Maytag washer.
Hello shelleyg537
Welcome to Fixya
My name is Huum,
You have a hose loose under the washer! or a hole in the hose
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Dec 12, 2008 | Maytag PAV2300 Top Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
268 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
