Question about KitchenAid KSRP22FNSS Side by Side Refrigerator
Icemaker dosn't work no water going to icemaker but have drinking
Kitchenaid refrigerator
  • Anonymous Mar 17, 2009
    my drain tray needs to be emptied
  • KitchenAid Master
  • 19,396 Answers
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
Kitchenaid refridgerator/freezer/icemaker model KBFS5ET5500 EVERYTHING WORKS BUT THE ICE MAKER...JUST QUIT. THERE DOES NOT SEEM TO BE A SHUTOFF VALVE AT THE BACK OF THE FRIDGE. I AM LOOKING TO SEE IF THE...
Hello Raymond,
In a most of cases if the filter were clogged it would affect BOTH the icemaker and the in door water dispenser,its never a bad idea to replace espically if they is a foul odor or taste in the ice or water. The water valve on the back is going to the most likely problem if the in door dispenser works yet the icemaker does not,a lot of times when the water valve is bad when its supposed to be fully closed cutting all water flow into icemaker it stays open a wee bit allowing water to seep through it causing the hose that connects to it ,running up the back wall into the icemaker to freeze up at the top where the tube enters into the freezer,that tube needs to be thawed, and to prevent it from freezing in the future the water valve needs to be replaced.
Goodluck,i hope this helps you to fix your icemaker,
Gene
Aug 09, 2011 | KitchenAid Superba Architect KSCS25INSS...
Icemaker quit making ice .. water supply to drinking water still working ..switch is on the on position
check the fill tube that brings water into icemaker..these sometimes freeze over..if it is, defrost and order new fill valve....or, you have a fill valve thats bad..
Jan 11, 2011 | KitchenAid Refrigerators
Icemaker stopped working. There is water to the refrigerator (is water to drink) but does not fill icemaker. Thanks, Gene
I changed the water inlet valve on the fridge. It still doesnt send water to the ice maker, but continues to send water to the door, so what do i do now?
Oct 15, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Icemaker inlet tube frozen. No water to icemaker. drinking water dispensor works fine.
If the tube is located behind the icemaker and to the left in the freezer simply either take a blow dryer to it or if you can remove the fill tube manually i would. This happens because your valve is leaking back alittle and if it reoccurs you'll need to replace the valve. Just thaw the fill tube and you'll start working again.
Feb 09, 2010 | KitchenAid Refrigerators
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Not makeing ice , defrosted frezzer, got drinking water, took back off by water lines, brown sylonied not getting power too send water up. what is wrong or were to from here
That is a water valve that supplies water to the icemaker and water dispenser. The icemaker is what energizes the valve and sends water to the icemaker. Change out your icemaker or you can just replace the module on the icemaker.
Sep 13, 2009 | Refrigerators
Ice maker won't make ice
SOLENOID BAD ON WATER VALVE OR ICEMAKER IS BAD
Apr 27, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRP22FNSS Side by Side Refrigerator Logo
218 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
