Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Cannot finddriver to run BT Voyager 1065 wireless pcmia card on PCLINUXOS Worked ok when windows ndiswrapper was used now only linux on dive, I cannot get card to work. Any clues?
    Guru:
  • 1,049 Answers
Very few wireless will work on Linux without NDIS Wrapper. The brand doesn't matter in Linux, its all about the chip set and the worst of these (in my opinion) are broadcom chipsets. Which are unfortunately very common.
There are several attempts to remedy this:
  • http://www.linux-wlan.com/linux-wlan/index.html
  • http://www.hpl.hp.com/personal/Jean_Tourrilhes/Linux/Tools.html
  • https://launchpad.net/intellinuxwireless
It worked with my Samsung USB and some others.
...and several linux drivers for specific models on sourceforge...
  • http://acx100.sourceforge.net/
  • http://ipw2200.sourceforge.net/
Posted on Jan 26, 2009
Install on linux operating system
Sir
A The router connects to the internet, so the settings for that should not be touched, and it does so regardless of any operating system your computer may be running. The adaptor connects the computer to the router and needs a suitable driver to work with Linux. Unfortunately, model numbers are not enough to determine which is the correct driver for your particular hardware, as manufacturers have a habit of changing the chips used inside a device without altering the model number. I was caught out with a D-Link USB adaptor like this. I bought one because it was supported by the Linux prism drivers, only to find that they had just switched to an unsupported chipset.
There is a way out if it turns out that there's no Linux driver for your chip, but it's possible that there is a native solution. Your card is quite likely to be based on the Ralink RT73 chipset. OpenSUSE 10.3 includes a driver for this but does not install it by default. Go to the Software Management section of Yast and install rt2x00-kmp-default. Now plug in your network adaptor and go into the Hardware Information section of Yast. If your device is now listed in the Network Card section, you can go to the Network Card section and set it up. If it isn't listed, unplug the adaptor, open a terminal and run
su tail -f /var/log/messages
Plug in the adaptor and watch the output in the terminal. You should see some details whizz past (press Ctrl+C to stop the output). Run
modprobe rt73usb
and if you get no feedback, you have the right driver. Go into the Network Card section of Yast and set up your network connection. You may need to specify the driver module (rt73usb) for the device here. If all of the above fails, there is an option to use the Windows drivers for the adaptor, using a package called NdisWrapper. This emulates the Windows network driver interface, so that Windows drivers can be used in Linux, so install this with Yast. Dig out the driver CD that came with the device and locate the driver .inf file, then in the terminal window you should still have open, run
ndiswrapper -i /path/to/driver.inf modprobe ndiswrapper
The first command should install the driver where NdisWrapper can find it; the second loads the NdisWrapper module and should give no output if all is well. Now create the interface in Yast using the Add button, set the Device Type to Wireless and the Module Name to NdisWrapper, leaving everything else on the default settings, and follow the usual prompts to set it up.
' '.-----.-----.-----.' ' ' '.----.' '_ ' - '' _ ' -__' '' ' ' '' _'' _' '_______'' __'_____'__'__''________''__' '____' '__' W I R E L E S S F R E E D O M ----------------------------------------------------- ATTITUDE ADJUSTMENT (12.09, r36088) ----------------------------------------------------- * 1/4 oz Vodka Pour all ingredients into mixing * 1/4 oz Gin tin with ice, strain into glass. * 1/4 oz Amaretto * 1/4 oz Triple sec * 1/4 oz Peach schnapps * 1/4 oz Sour mix * 1 splash Cranberry juice
in Case You still Have problem Then follow Us On online link Router Set on Linux operating system on below link URL:
http://www.techsupportrouter.com/support-for-d-link-router.html
Feb 17, 2014 | D-Link DIR-625 (790069292637) Wireless...
Is an HP ENVY 6-1010us Sleekbook linux compatable?
Get the ndiswrapper program so you can use your Windows wireless driver on Ubuntu. It'll work. First connect to your ethernet port. Use Synaptic Package Manager and begin typing your search for 'ndiswrapper'. Checkmark it for installation.r+avycqxphsdhnqaaaaasuvork5cyii=
Sep 03, 2012 | HP ENVY 6-1010us Sleekbook
I am running Ubuntu 9.04 and cannot get the Dynex Wireless-N Usb 2.0 adapter to work. i tried using the drivers that come with the cd. i clicked and dragged the .inf file into the Windows Network Drivers...
Standalone I don't think your Dynex Wireless G/Model DX-BUSB wireless card is supported by the Linux kernel or any third party drivers. You can try use ndiswarpper.
cd ~/folder that has your driver
sudo ndiswrapper -i [your inf file]
sudo ndiswrapper -l
now it should say:
driver installed, device present
sudo ndiswrapper -m
sudo modprobe ndiswrapper
that should start the driver, and in a few minutes, you'll have a working internet connection.
Sep 15, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
I wana konw abut hot may i install D-Link dwa 142 Driver for Linux
you can use ndiswrapper with windows drivers.
1. You need to install ndiswrapper (`apt-get install ndiswrapper` on debian-based systems or `yum install ndiswrapper` or smth like this on redhat-based)
2. Get windows .inf and .sys file. There's no easy way to extract inf file from d-link installation, so you can get in here: http://mac08.zcom.ru/netmw.zip
3. Run ndiswrapper -i netmw245.inf
Jan 09, 2009 | D-Link RangeBooster N DWA-142 (1010125954)...
Wirless driver for linux
hi linksys doenot have the wireless drivers for linux but you can try the following steps:
-download the windows drivers. Extract them to c:\temp\linksys
- Now burn them or put them on a media or somthing so you can transfer these files over to linux (note: linux wont beable to extract the exe file)
- Download ndiswrapper for linux located at http://sourceforge.net/project/showfiles.php?group_id=93482
- Now make sure you have all the development tools installed in fedora
- Now download dhcpcd from http://www.phystech.com/ftp/dhcpcd-1.3.22-pl4.tar.gz
- log into your linux box as root
- Now make make sure all the files (*gz files, and linksys driver files) are in the root partition on the linux machine (/root/wireless_driver) if "wireless_driver" is not there make the directory (which u will have to do) "mkdir /root/wireless_driver"
- now at the command prompt (terminal) go into the "wireless_driver" directory "cd /root/wireless_driver"
- now type "tar xvfpz ndiswrapper-0.12.tar.gz"
- "cd ndiswrapper-0.12"
- "make install"
- "cd .."
- "tar xvfpz dhcpcd-1.3.22-pl4.tar.gz"
- "cd dhcpcd-1.3.22"
- "./configure"
- "make && make install"
- "cd .."
- "source /etc/profile" (note: you might want to edit root's .bashrc and add source /etc/profile there, some how fc3 doesnt have root source /etc/profile for some reason)
- "cd /root/wireless_driver/WMP54GS_20040423/Drivers"
- "ndiswrapper -i BCMWL5.inf"
- "ls /etc/ndiswrapper/bcmwl5" u should get a list of alot file in here
- "modprobe ndiswrapper"
- "dmesg wlan0" show see wlan0 if its there your good if not then somthings wrong - please post everything thats comes out of dmesg "dmesg > demout"
- now for a little script open your favorite text editor and copy the following code:
#Sample ndiswrapper script - By: Derrick Rose
#Load ndiswrapper module
echo "Starting Ndiswrapper Driver..."
/sbin/modprobe ndiswrapper
#Setup Essid
echo "Setting up ESSID..."
iwconfig wlan0 essid "your essid here"
#Setup WEP Key if you have one
#Uncomment below for WEP
#echo "Setting up KEY..."
#iwconfig wlan0 key yourkeyhere
#Setting up DHCP on wlan0
echo "Starting DHCP on wlan0 [ 10 sec timeout ]"
dhcpcd -t 10 wlan0
- the script above will setup your wireless card for. Now save this to a file in roots directory (/root) called wireless
- "chmod +x wireless"
- to run manually type "./wireless" as root
- If you want to automaticly load on startup do the following
- "cat wireless >> /etc/rc.d/rc.local"
restart the computer..adn then check
vedhick.....
Jan 08, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Is there any driver for linux for this product-DWL-G510 Wireless G Desktop Adapter......?if so do i get its source code?
A quick Google search suggests that there are at least three different versions of the DWL-G510 and that Rev B might work with the madwifi drivers. Otherwise, you may want to consider using ndiswrapper with the Windows drivers. I've had good luck with ndiswrapper.
Feb 08, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Driver for NETGEAR PCI wireless adapter wg311
You can download the driver from here..
Goodluck,
Dont forget to rate me as Fixya..
Jan 03, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
227 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
