Question about Irons
How do I descale my tefal pro minute aqua plus iron
  • 833 Answers
SOURCE: Tefal Pro Express Steam Generator Iron
Irons are generally not worth repairing. That said, try to clean out any mineral deposits with a mixture of 1/3 vinegar and 2/3 water. Put in the usual amount. Warm the iron, try to get steam. Empty the iron and do it twice more. Then, rinse it out with plain water.
You may get lucky!
Posted on Jan 23, 2008
  • 3 Answers
SOURCE: tefal 400 iron auto shut-off light stays on
TEFAL B.800
AUTO LIGHT ON,BUT NOT TEMP LIGHT.NOT HEATING UP.HAD BEEN USING BUT UNPLUGED WHILE I GOT MOE IRIONING.
Posted on Feb 04, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: tefal express iron cleaning
Thankfully I was able to clean the boiler compartment, by unscrewing the large bolt on the boiler, cleaned with water only, loads of brown yuck came out, It would then not allow me to use the steamer, Waited until the next morning tried again and working brilliantly again.
Jopey
Posted on Aug 23, 2008
ginko
  • 19396 Answers
SOURCE: tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Posted on Apr 22, 2009
I have a tefal pro express turbo GV8150 and there is constant team coming from iron without me touching the steam button. Can anyone help with a diagnosis and or possible fix?
constant steam means the control valve is not working
descaling may fix the problem
the other fix is a new iron as the cost to repair is generally more that a replacement price
Sep 30, 2016 | Tefal Irons
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
I need descaling instructions for Tefal Ultraglide easycord55...Mislaid instruction booklet....Thank you
thank you solved de scale instructions for Tefal Ultraglide easycord 55, found manual on net....
Jan 09, 2010 | Tefal UltraGlide Easycord FV4256 Iron
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Jan 26, 2009 | Tefal UltraGlide plus 1656 Iron
You may get lucky!
Jan 21, 2008 | Irons
Irons Logo
48 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
