Bush a1447cr6 warning fault light
2000 Bentley arnage airbag warning light on How remove
The light is on to warn you the system has sensed a fault and the air bag system is shut down as a result. To get the light off you must have the system scanned for the fault code and the fault repaired, then the light will go off.
Mar 15, 2018 | Bentley Cars & Trucks
I got dash warning lights coming on. please advise
There are many warning lights that can come on , some very serious , and you should shut down the engine and not drive further till the fault is repaired , oil pressure, overheating , brake fail , the above warning lights are classed as serious, most other warnings are minor but should be repaired as soon as possible . The drivers hand book will show the symbol for each fault.
Mar 03, 2016 | Cars & Trucks
I have a '99 dodge grand caravan se, while in park the abs light came on, the battery light came on, and the check engine light has been on,
Looks like you have a few issues there.
1. The battery warning. This is indicative of a weak battery and if your battery is 3 years old or more I would replace it.
2. If you have a weak battery this can trigger other warning lights in the vehicle, typically the ABS warning but sometimes other warning lights as well depending on the electronic features in the car. If you replace the battery this should correct the battery warning and most likely the ABS warning if both of these warnings appeared at the same time.
Normally, once the ABS warning is displayed the anti lock braking system(ABS) will be shut down. Whilst your braking will be normal, if you brake too hard and lock up your wheels on a slippery road there is no ABS assist to prevent the brake lock up which you have when the system is working.
3. If the alternator on the engine is not generating sufficient power and thus not charging the battery at all, or very little, you will likely get a battery warning light. I don't know if your 1999 vehicle has a warning light to indicate a faulty alternator or not.
4. Check Engine Light.
You suggested the CE warning has been showing up for a few days and before the battery and ABS warnings popped up.
The CE warning can be caused by dozens of different engine issues.
The vehicle needs to be scanned with the appropriate scan tool to see what fault codes the onboard computer is generating because if you have a CE warning light there will be fault codes generated 99% of the time.
Once these fault codes have been pulled the mechanic can start to diagnose the cause of the problem or problems. Each engine fault code your car's computer is generating can be caused by different types of problems so it is important that they diagnose the issues correctly. Otherwise your Check Engine light will remain on as long as the causes are not identified and fixed.
Dec 29, 2015 | Dodge Cars & Trucks
Why battery gauge needle drops and check gauges light comes on - system not charging
warn bushes in the alternator, when the alternator warms up the bushes will come away from the pole, in turn turns the power off, just means the bushes are so warn down they heat up and the springs shrink back in and when it cools down again the bushes are connecting again till it heats up again.
Aug 16, 2017 | 1986 Dodge Lancer
2000 regal security light on
The ECU had reports that repeated which in turn would bring on the warning light. When you turned the ignition off then on again if the fault was no longer being reported it would put the warning light out. The fault memory will still have that record. Best get the fault memory interrogated (special fault reader required) to find out what action if any is required and also clear the memory.
Nov 10, 2017 | Buick Cars & Trucks
I have a 40 inch bush tv the power light is on but when I try to turn the tv on the power light flickers and nothing happens, please help
Blinking of power light indicates there is something fault with internal circuit. These are called blinking codes. If you wish to know more about blinking codes to Bush TVs, check this link. Pull up older posts there.
Mar 20, 2013 | Bush Televison & Video
Meaning of ABS light
On vehicles equipped with antilock brakes (ABS), a second warning light is provided to warn if a problem occurs within the ABS system. The ABS lamp comes on when the ignition is turned on for a bulb check, then goes out after the engine starts. If the ABS warning light remains on or comes on while driving, it indicates a fault has occurred in the ABS system.
What happens next depends on the nature of the fault. On most applications, the ABS system disables itself if the ABS warning light comes on and remains on.
Oct 24, 2012 | 1999 Ford Ranger SuperCab
WARNING LIGHT ON THE DASHBOARD
Cluster warning lights
Whenever this warning or any other stays on in the dash it is indicating that the systems control module has detected a fault, it then disables the system as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Sep 26, 2012 | 2002 Audi A6
Hp designjet 500plus ,first time i change carriage belt ,but now it shown allignment error..
Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
May 30, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
Washing Machines Logo
Top Washing Machines Experts
