Question about Lite On SOHD - 16P9S Internal DVD Drive
DVD drive does not open and does not recognise blank DVD's
I have a liteon HDD/DVD recorder/player in which DVD drive does not open the door nor does it recognise blank DVD's. I have clean the lens with an Air spray. No improvement.
As this is not working, I require a replacement drive Model No. DDW813SO7C. Where can I get this.
Your help will be appreciated.
  • 1 more comment
  • balvant81516 Jan 27, 2009
    Thanks, I will try this.
    This is not a desk top item. It is an Liteon HDD/DVD recorder/player.
    Yes the drive has worked for 2 and a half years. I have had the equipment for just under 3 years.
    Thanks
    Brigadier General:
  • 8,619 Answers
Hi!
You can buy it from the links--
Link 1
Link 2
Thanks
Rylee
Posted on Jan 26, 2009
  • Lite On Master
  • 4,806 Answers
Hi there
It certainly sounds like the DVD/RW has gone down, you can pick a new one up from a reputable company like amazon.com. check this out.
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=dvd+rewriter&x=0&y=0
Good luck and thanks for using Fixya!!!
    Sergeant:
  • 378 Answers
There is a mechanical eject hole on the optical drive. Simply insert the tip of a
pen or paperclip into the hole and push to eject the tray. (If your computer's
optical drive is a slot-load model, it will not have an eject hole.)
as also try to upgrade the latest drivers for your dvd drive.also check out with another company dvd discks and also remove and reinsert the connections and check out again.
  • 916 Answers
    President:
  • 1,214 Answers
What OS are you running?
Has the drive ever worked?
How long have you had the drive?
If you want replacement, FixYa is not who you need to be talking to. Either return to the store you bought it, or contact the manufacturer.
  • Lite On Master
  • 13,433 Answers
Hi
If this is a desktop computer, Any generic dvd drive will do.
I suggest you buy a new drive from newegg
  • 137 Answers
You can use any ide drive it doenst need to be that model at all...just about any drive will work in that unit
LITE ON HD-A740GX ONLY HAVE DIGITAL SIGNAL HOW DO I TUNE IN CAN I TUNE IN
You must connect a digital TV box between your arial and your Liteon, so the arial cable goes into the digital box, and use a SCART cable from the digital box to the Liteon. Then record using the SCART input on the Liteon. Another SCART cable can be connected from the Liteon to your TV, so you can view what you have recorded.
Apr 30, 2012 | Lite On HD-A760GX DVD Recorder / HDD...
Where can I get repaired in India LiteOn DVD Recorder ?
There is no ,LiteOn authorised repair centre in India. You can get in touch with a local repair technician for the same . Alternatively you send Liteon support people an email. Incase they have a tieup with an indian service & repair company.They would let you know.Find the link below
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=70
Thanks for using fixya
Proton
Sep 05, 2009 | Electronics - Others
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
lite-on dvdrw in model HD-A760GX will not recognise dvd disc. KEEPS STATING TO INSERT BLANK
Jan 26, 2009 | Lite On SOHD - 16P9S Internal DVD Drive
Liteon 5045 problem in playing normal movie DVD's
The DVD drives are very unreliable and just get more temperamental with age. I replaced mine with a Lite-On SOHW-1213S. The DVD is too big to fit in the old ones place so it sits on top of the unit with the cable going through the slot, but it works brilliantly.
Nov 04, 2008 | Lite On LVW-5045 DVD Recorder
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Liteon lvw-5045
If your DVD recorder can still access CD's the goto the following link and select your DVD recorder from the drop down list under audio/video and download the firmware file.
http://www.liteonit.eu/index.php?option=com_wrapper&Itemid=178
Write the file contained in the zip file to a CD and insert it into your DVD recorder. Follow the instructions in the user manual to complete the firmware update.
This should solve your problem.
Feb 19, 2008 | Lite On LVW-5005 DVD Recorder
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Oct 13, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Lite On SOHD - 16P9S Internal DVD Drive Logo
149 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
