Question about Zmodo Surveillance CM-Z2213GY 1/4inch CCD 420TVL 22X Zoom PTZ Camera Retail
Zmodo ptz cm-z2213gy disassemble to remove front lens
We need to remove the lens due to moisture in the lens
I have moisture inside lens how do I remove Headlight lens cover to clean?
Hello, go here and watch the youtube video will show you how to remove moisture:
Please rate my answer, thks.
How to Fix Headlight with Water or Moisture in it
Dec 05, 2015 | 2005 Scion xB
After power failure - I am getting no signal on monitor
After power failure at my house when power came back on my security zmodo dvr monitor didn't come back on it said no signal
Jan 19, 2015 | Zmodo Surveillance cm-Z2212GY Weatherproof...
How do i remove moisture from my headlights?
First, you should locate and seal the crack with silicone or equivalent. Next, you should remove the lens from the vehicle (if possible) and all the bulbs, connectors, etc. Then get the lens in a warm, dry place to air out, direct sun light works, but be careful not to warp lens. Once it has dried out and all moisture has left, double check that all seams and cracks are sealed, then reinstall lens. Make sure all bulbs, connectors, etc are secure and tight to prevent moisture from returning. Lastly, enjoy moisture free lenses!
Oct 29, 2014 | Vehicle Parts & Accessories
Zmodo troubleshooting
Sound like someone turned off the focus asst light in the the menu of the camera, Need to turn it back on.
Sep 07, 2014 | Zmodo Surveillance CM-S38901SV 540TVL High...
Removing mold from inside front lense element 80-160 pentax 645 lens
Before you remove the lens element, consider this. Do you have a lens collimator and other equipment necessary to ensure proper alignment when you replace the element? If you don't, please leave lens disassembly/reassembly to a trained professional with the proper equipment.
Dec 05, 2012 | Cameras
Lens shutter is not opening and SW led is flashing
The gears in the lens cover mechanism in these cameras are susceptible to debris. This requires disassembling the camera to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem due to the fact that the front case will need to be removed and the lens blind mechanism disassembled to remove the debris and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com
Oct 20, 2011 | Canon FS11 Flash Media Camcorder
Lens won't close
Oct 01, 2011 | Canon Video Cameras
Fell into water, still can used, but got watermark inside lens.
You can use some absorbents to dry off the residual moisture but the marks might remain due to stain of the water. So try to use a hair dryer to warm the camera very carefully. Once there is no trace of water, but the marks remain on the lens , then it is important to remove the lens assembly after dismantling the camera so as to clean the lens using proper lens cleaner.
Attempt only if technically inclined and with proper tools.
May 04, 2011 | Cameras
Zmodo Surveillance CM-Z2213GY 1/4inch CCD 420TVL 22X Zoom PTZ Camera Retail Logo
108 people viewed this question
Top Zmodo Cameras Experts
Steve
Are you a Zmodo Camera Expert? Answer questions, earn points and help others
