Question about 96-08 Ford Powerstroke Dashscan Data Monitor
Oil pressure gauge jumping - 96-08 Ford Powerstroke Dashscan Data Monitor
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 47 Answers
Have you changed the oil pressure sensor on the motor the sending unit could be bad
Posted on May 17, 2013
Oil gauge
cold oil is thicker, higher rpm=more pressure .factory guage is actually working like it should. if worried hook external guage on oil galley plug and check oil press.manually.
Apr 15, 2014 | 2005 Nissan Xterra
Oil pump ford explorer
No that is not the pump that you smell. You need to have a test gauge hooked up to verify that you have good oil pressure, if it is ok then replace the sending unit for the oil pressure gauge.
Mar 20, 2014 | Ford Explorer Sport Cars & Trucks
What would cause no oil pressure
Clogged oil pump pick up screen, a stuck open pressure relief valve on oil pump, clogged oil passages. Verify gauge operation, unplug oil pressure sender , turn key on, have someone observe the gauge, for single wire, ground the lead to the engine block, gauge should go up. For two wire lead , jump the ends to each other.
Dec 21, 2013 | 1999 Dodge Ram
My 2001 Ford Ranger Edge oil pressure gauge has been jumping around all over the place. Took it in today and they said pump needs replacing... and that they had to remove the engine to do so at the tune of...
Your oil pressure gauge works with the oil pressure sensor, which is screwed into the block, to transmit a reading. A faulty oil pressure sensor can cause the reading on the gauge to be erratic. You may have a bad oil pressure sensor. You should also inspect the wires going to the sender to make sure they are not loose, corroded, or shorted. If a new sending unit doesn't work, you can check the oil pressure with a manual pressure gauge. Testing for oil pressure involves fitting the oil pressure gauge with an adapter. Then you will need to determine if you have a gauge problem or an actual oil pressure problem.
Oct 22, 2013 | Ford Cars & Trucks
1989 chevy c1500 truck has rebuilt engine, goes dead sometimes. engine doesn't sound even in tone when idling. More likely to cut out when. air conditioner is on. Oil pressure gauge jumps around o
You just need to find an older Repair shop that still has the old test gauges. Every so often the Onboard computers are replaced with more capable models. The connectors are different, so you need the proper old style diagnostic scanner.
You can still use the old style Vacuum gauge to diagnose some things and set the carburetor. You should have an electric/vacuum solenoid on the carburetor to compensate for the A/C running at idle. Someone may have disconnected it, or adjusted the idle speed missing the solenoid.
You do not want to have high idle rpm just because you have an A/C; its suppose to adjust when the A/C cycles off and on and maintain a stable idle.
That said, the oil pressure may be more steady at idle if the RPM is steady. Now for fluctuating oil pressure at high RPM, you may have a bad fit inside the oil pan with the oil pump pick-up tube. There are pressure relief springs in some oil pumps, oil filters have relief springs, and your oil pressure gauge may be wrong.
Oil pressure gauges are not a major expense, or even have a Mechanic hook up a test gauge temporarily to verify pressure.
Jun 18, 2013 | Home
Oil pressure gauge is jumping from 20 to 40 psi. Is this a sign the oil pump is bad?
Probably not, as oil pumps are usually "forever" , unless the oil changes are not done and the system plugs up.
I'd recommend you find a garage that will remove the oil pressure sending unit and screw in a real oil pressure gauge, and test it.
Oil pressure switches that screw into the block fail occasionally, and dashboard oil pressure gauges sometimes fail also.
Be blessed.
Feb 23, 2013 | Cars & Trucks
Oil pressure is jumping from 20lbs to 0lbs,truck almost dies then the oil pressure jumps back up to 30lbs then back to 10lbs ,
To start, take the vehicle to a dealer and ask them to screw an oil pressure gauge into the block hole and check your oil pressure whilst idling and while driving it.
I have a 1993 and it does the same thing, but the problem is only the gauge itself.
If it is actually having such oil pressure fluctuations, you may have a defective pump, a clogged pump filter screen, or a clogged oil filter.
God bless your efforts.
May 18, 2017 | 1992 GMC Sierra
Oil pressure gauge is jumping up and down and then it loses pressure then itll come back and jump up and down again no knocking or noises
Sounds like you had better check your oil level before you have a knocking noise. If oil level is ok, change your oil pressure sender.
Sep 05, 2011 | GMC Sierra 2500HD Cars & Trucks
1995 jeep cherokee sport 4.0L. Oil gauge keeps sending false message ie. jumps from almost center past the highest point on the gauge. How do I fix this problem? where is the gauge sender located?
OIL PRESSURE SWITCH-I'm not sure if this is the gauge sender, though. 1995 Jeep Grand Cherokee 4WD 4.0L MFI 6cyl The Oil Pressure Switch is located: Under hood, passenger side, lower engine area, above oil pan, mounted in engine block.
Nov 01, 2010 | 1995 Jeep Cherokee
Oil gauge jumps back and forth on a 2000 escalade at lower rpms
First make sure you have the proper oil level.
Then;
It's one of two things. The oil pressure switch or the oil pressure sender.
I think you can start with the pressure switch.
You try an analog oil pressure gauge on to test the oil pressure if you want to. That would
verify the oil pump/pickup.
May 04, 2009 | 2000 Cadillac Escalade
96-08 Ford Powerstroke Dashscan Data Monitor Logo
Top SCT Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a SCT Vehicle Part and Accessory Expert? Answer questions, earn points and help others
