Question about Welding Tools
Have a Millermatic 200 wire welder! s/n:JJ048290!
Problem! When you go to touch the metal you are about to weld, the wire wouldn't even spark! Welder don't have the right hum to it either when turned on and when you contact the metal with the wire coming out the gun you don't have that contact sound or click to the machine! Checked the fuse's in the fuse box and they are ok! You can hear the machine when you first turn the switch on or off on the panel, but it just don't have the right sound to it like it did before!
  • Ron Jones
    Ron Jones May 11, 2010
    Couple of items to check out: What size (amps)set is it. Single phase or three phase: All connections are tight: the Earth is in good condition: plates to be welded are clean: contact tip-rollers and liner is all the same sizes.Check on the front panel for a switch indicating Spot "......." or Stitch "--------" set these to off.
    ; Wire feed rollers turn when the trigger is pulled: The torch assembly is good condition. let's know how this goes
+1 a-tripod. That's the first thing that came to mind when I read it! Can't forget the ground clamp. Or, nod your hood down when it's layin' on the bench!
Posted on Nov 25, 2009
    Scholar:
  • 195 Answers
The problem is your project is not grounded, attach the grounding cable from your welder to your project your welding.
Posted on Jan 29, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
Why does the wire weld when I touch the metal?
BE CAREFUL. That sucker is hot and you have current going through it! If you get a voltmeter you will detect the juice.
Aug 31, 2015 | Welding Tools
My welder is not sparking strong enought to weld I raise the amp all the way and it is not sparking like it should what could be the problem
make sure there is nothing getting in the way of the current flowing through the ground. slow down and keep the arc close to your metal.
Jan 27, 2013 | Lincoln Electric K1297 AC/DC 225/125 Stick...
What is the basic technique in welding
Hi:
Well don't know were to start, basic technique goes according with the type of metal to weld and type of wire to use.
I think if will be better if you read the basics of welding with MIG machines with an owner's manual. Check the link and go to section B-7.
http://www.lincolnelectric.com/assets/servicenavigator-public/lincoln3/im564.pdf
Sep 13, 2011 | Welding Tools
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
1,255 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
