Question about RCA P61310 TV
RCA Model P61310
T.V. was not coming on, when it was plugged in you could hear the t.v booting up but the power light would not come on. Now the power light stays on but no picture. And you can turn it of with out unplugging it
  • 4 more comments
  • MAYUR UPADHYAY Nov 08, 2007
    tv no power no sound no gren light
    NO POWER
  • rpracer Dec 12, 2007
    I have the same problem. Thanks. Can you tell me where the relay is located?
  • Anonymous Mar 18, 2008
    it doesn't turn on
  • thinkquiet Apr 02, 2008
    I have the same problem. Thanks. Can you tell me which relay and where the relay is located?
  • rvictorious May 11, 2010
    can u tell me what relay it is & where it is?
  • 139 Answers
The Relay Need To Be Replaced Did you Have A Storm Latley?
Posted on Jul 19, 2007
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
Rca P61310 WILL NOT COME on
This by the model is an older set: when you try to turn on do you see a brief flicker on the power light (should be a green indicator)?
Mar 25, 2012 | RCA P61310 TV
My RCA big screen tv sound shuts off
This could be several different problems. You could have loose solder joints, bad capacitors, or the aodio ouput IC could be getting hot andf failing and needs to be replaced.
Jan 10, 2010 | RCA P61310 TV
Power does not stay on
Faulty power supply/control board. Needs professional service, unless you have the experience.
Charlie
Aug 29, 2009 | RCA P61310 TV
RCA P61310 TV, won't come on
Resolder flyback cold pins that with the time dries. If this is not fix the situation take it to the technician...
Aug 17, 2009 | RCA P61310 TV
Rca p61310 power up for 15 seconds and the power light turns off
Hi, this is a faulty power board. i would replace this damaged circuit board. this Will fix this issue you are having at this moment with your unit.The reason for the on/off cycling fans is due to the power board controllers inability to open the main fan circuit, which shuts off the fans once you power down the unit.
May 18, 2009 | RCA P61310 TV
RCA P61310 Works on all inputs but ant a
The other inputs bypass the tuner, so I'd be looking at tuner failure. RCA sets are known for having poor solder connections inside the tuners. I would start there. If you are not comfortable with working insode the set or can not solder, check with a local service shop to get an estimate for resoldering/replacing the tuner.
Dan
Feb 13, 2009 | RCA P61310 TV
Part number for a green crt board on a RCA P61310
tv comes on and is green and then turns it self off
Nov 21, 2008 | Televison & Video
No power, no light, not booting up at all.
Check the fan on the motherboard.Like a computer if it isnt running the tv wont come on.This fan runs 24/7. I had the same problem I replace it with a computer fan.been working again for 2 yrs.
Dec 13, 2007 | RCA P61310 TV
Rca p61310 61 inch tv
This happened to my TV a year or so ago. It ended up being a capacitor in the power supply. It took the tech about 10 minutes to replace and cost me 400 bucks!! He wouldnt tell me what he replaced, but I be it was a 2.00 part. If you are good with a soldering iron, you might be able to find it and replace it, but if you mess something up, it will cost you. The tuner module was over 700 bucks.
Oct 12, 2007 | RCA P61310 TV
RCA P61310 TV Logo
287 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
