Question about Reebok Exercise & Fitness
E3 error z9 reebok
E3 error on new treadmill.
SOURCE: Need a Reebok treadmill repairman.
I can fix it for you. Just post it to me in London. Hope this was of help!
Posted on Mar 02, 2009
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
greenspan
  • 1734 Answers
SOURCE: I have just bought a Reebok 3 series treadmill.Do
If manufacturer and google are of no help, ask them. They already found some hard to find Reebok manuals. I guess they have the TR3 for download on their site.
Posted on Aug 23, 2009
  • 40 Answers
SOURCE: I have lost my key for the Reebok Treadmill
Any magnet will do. Otherwise order a new one from the manufacturer, other retailer or ebay.
Posted on Nov 01, 2009
How do I oil the belt on on an horizon ct5.4 treadmill?
Hi
When I oiled my Reebok Z9 treadmill the silicon liquid that I purchased came with a syringe and a tube attached
You simply pulled the belt up slightly inserted the tube and squirted the solution toward the middle of the belt then repeat the process on the opposite side then turn on the treadmill and walk on it moving your feet from the middle of the belt to the outer edges
I hope this helps Nick
Apr 12, 2018 | Exercise & Fitness
I have error code 02 on my reebok z9 run treadmill what does it mean
Go to www.reliable-store.com and get info on whether to repair or not, service it, and how to repair etc
Mar 09, 2018 | Reebok Exercise & Fitness
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
Oct 23, 2016 | Reebok Exercise & Fitness
Reebok z9 treadmill beeping with error e01,this happened once before then went ok,driving me mad any help please
Try to check the Speed sensor. Check for its aliment also check is there is any dust accumulated on it .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 13, 2016 | Reebok Exercise & Fitness
Knocking sound on Reebok z9 treadmill. Why does it happen? Did i ovover tighten the belt? Its brand new but knocking starts as it gets quicker. Also is suppose to go to 16kph but only goes to 10kpm. Any...
What is the frequency of the knock? Is it every second, few seconds, or very fast? This can tell if it has something to do with the track or the motor.
Feb 01, 2015 | Reebok Exercise & Fitness
Reebok Treadmill error code 5
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
Feb 20, 2014 | Reebok Exercise & Fitness
My Z9 treadmill will not turn on... i've flicked on the power swtich and the switch on the machine but it wont sstill come on. what can i do?
Our Z9 has just done the same, switched on the power but it doesn't turn on. Was just wondering if you managed to fix yours and if so how?
Thanks.
Sep 12, 2013 | Reebok Exercise & Fitness
E2 appeared in monitor of reebok z9
adjust the speed sensor, clean it, tight the plug very well, see the diagram
adjust the reed switch, clean it, tight the plug very well, see the diagram
test the input voltage motor, if there are the motor need repair
4) test the output board, for input voltage motor, if there are NOT the board is faulty. see the diagram
.God bless you
Oct 10, 2012 | Reebok Exercise & Fitness
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
Exercise & Fitness Logo
61 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
