Question about Stairmaster 4400 PT Stair Stepper
How do i remove covers from stairmaster??
How do i remove side covers from stairmaster? The clips have been removed
  • Stairmaster Master
  • 914 Answers
Removing the cover
Try using a pair of diagonal pliers. Do not squeeze to hard or you will cut the clip. Diagonal pliers We do offer replacement clips if you damage any in the process.
Rivet Kit Stairmaster SM22847 SPORTSMITH net
Feb 06, 2014 | Stairmaster 4400 PT Stair Stepper
Tip
Alternator Belt Replacement for Stairmaster 4000PT Stepper
Stairmaster Stepper 4000PT Alternator Belt Replacement WARNING: The belts must be properly tensioned. A belt that is too loose will cause slow and sluggish operation. A belt that is too tight will cause excessive noise and belt wear.
  1. Remove side covers.
  2. Loosen the adjustment screw that mounts the alternator to the alternator brace and the pivot adjusting bolt that mounts the alternator to the frame.
  3. Pivot the alternator down and remove the belt.
  4. Make sure the is centered on the pulleys during installation.
  5. Pivot the alternator up or down as necessary to allow 1/4" (0.6 cm) of belt deflection with fingertop pressure at the midpoint between the two pulleys.
  6. Tighten the alternator adjustment bolt. Verify 1/4" (0.6) deflection in the belt.
  7. Reinstall the covers
How to Replace Alternator Belt on Stairmaster 4000PT Stepper
on Mar 10, 2015 | Stairmaster 4000PT Stepper
Tip
Replacing a Spring Pulley on Stairmaster 4000PT Stepper
Stairmaster Stepper 4000PT Spring Pulley Replacement
  1. Remove the bottom cover.
  2. Unhook the pedal arm return spring from the spring hanger.
  3. Remove the snap ring from th pulley shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  4. Slide pulley and washer off the shaft.
  5. Before reinstalling the pulley, clean the pulley shaft thoroughly with a clean, dry cloth. Apply a thin coat of multipurpose grease to the pulley shaft.
  6. Slide the pulley and washer onto the shaft. Install the snap ring.
  7. Route the spring under the spring pulley.
  8. Hook the end of the spring over the spring hanger. WARNING: Do not twist the spring during installation. It will wear excessively and reduce the life of the spring.
  9. Reinstall the cover.
How To Replace Spring Pulley on Stairmaster 4000PT
Belt continues to slip off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This video covers the installation and adjustment of the Eccentric Hub Assembly for the Stairmaster 4400PT/CL and 4600PT/CL Steppers.
The video begins with the Eccentric Hub Assembly removed from the unit. If you need help removing the Eccentric Hub Assembly from your stepper, please see our video about the Eccentric Hub Assembly Removal.
Tools Needed: Socket Wrench, 7/16" Socket, Adjustable Wrench or 7/16" Wrench
  • Begin by placing your HTD toothed belt around its pulleys. This allows you to set the proper belt tension before mounting the Eccentric Hub Assembly to the frame. The "egg" shape of the Eccentric Hub allows for adjustment of the belt tension. Rotate the hub counter clockwise to tension the belt. Proper belt tension allows about ¼" of play.
  • Line up the 4 bolts through the Eccentric Hub Assembly and the frame. Be sure to place the bolts facing the same direction as noted from removal of the old Eccentric Hub Assembly.
  • Once all the bolts are aligned, retighten them to the frame using the socket wrench with socket on one side and the other wrench on the opposite side.
  • Reinstall the poly-v alternator belt.
  • The Eccentric Hub Assembly installation and adjustment is now complete.
Stairmaster 4400 4600 Eccentric Hub Installation Adjustment
Sep 30, 2013 | Stairmaster 4400 PT Stair Stepper
How to change the battery
Remove the mid cover and top covers and unplug the battery from the
power control board.Locate pins #1 & 2 in the end of the cable. Use a
voltmeter on the new battery to verify that the voltage is a minimum of 6.1 VDC. Connect the new battery to the proper terminals and reinstall the battery. Replace the covers and you are done. This video will show you how to remove the covers. It can be a bit tricky the first time.
Stairmaster Stepper 4600CL Parts Battery Hub Assembly SPORTSMITH net
Jan 18, 2012 | Stairmaster 4600 Cl Cordless Freeclimber
Tip
Drive Chain Replacement on Stairmaster 4000PT Stepper
Replacing the Drive Chain on Stairmaster 4000PT
  • Remove the master link from the drive chain.
  • Remove the drive chain from the sprockets.
  • Reinstall the drive chain, ensuring the master link is properly installed.
  • Check the drive chain tension. There should be a total of 1" to 1-1/2" (2.5 to 4.0 cm) of play, up and down, at the slackest point in the chain. If the drive chain tension needs adjustment, refer to the "Drive Hub Assembly" section.
    WARNING: If the drive chain is too tight, the drive train will wear excessively, shortening the life of the drive hub assembly. If the chain is too loose, the machine will be noisy and will operate at less than peak efficiency.
  • Lubricate the chain with 30W motor oil and wipe off the excess.
  • Reinstall the covers.
http://www.sportsmith.net/faq.aspx?did=8C1A2D6B-027C-4681-BBD3-6099804CB674
Tip
Drive Hub Assembly Replacement for Stairmaster 4000PT Stepper
Stairmaster Stepper Drive Hub Assembly Replacement
  1. Remove the side covers.
  2. Remove the step chain retainers.
  3. Supposrt the pedal arm. Unhook the pedal arm return spring from the spring hanger. Lift the step chain up and off the clutch sprocket and lower the pedal arm to the floor. Repeat on the other side.
  4. Remove the snap ring from the left end of the drive shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  5. Remove the drive chain.
  6. Remove the sprocket and other small parts from the left side of the hub assembly.
  7. Slide the drive shaft to the right, out of the hub assembly. If you remove the right-hand clutch sprocket form the drive shaft, do not confuse it with the left-hand clutch sprocket.
  8. Loosen and remove the two remaining bolts and nuts that hold the hub assembly to the frame. Remove the hub assembly.
  9. Inspect the drive shaft, bushings, thrust washers, and clutch sprockets for excessive wear or pitting. Replace any worn components.
  10. To reinstall the hub assembly, carefull reverse the disassembly procedures. Be sure that the right- and left-hand clutch sprockets are positioned correctly; the wide shoulder of the sprocket should be facing away from the hub on both sides.
  11. Chain Tension. The drive shaft is mounted in an eccentric hub. Rotate the hub so the marked hole is in the 12 o'clock posistion, lining up four holes in th hub with the four holes in the frame. Use this hub position when reinstalling the drive chain since the distance between the drive and the transmission shafts is at a minimum. The hub is in the proper position when the drive chain has a total of 1" to 1-1/2" of play, up and down, at the slackest point in the chain. If it is necessary to increase the tension or tighten the chain, rotate the hub counter clockwise until the chain has proper tension.
  12. Reinstall the covers.
How to Repalce the Drive Hub Assembly on Stairmaster 4000PT
on Feb 25, 2015 | Stairmaster 4000PT Stepper
My battery needs replaced. Where does the new battery go? Can I get an A/C power source instead? I go to LifeTime Fitness and all of their Satirmasters are plugged into an outlet on the floors. Seems like...
yes you can get an adapter to plug it in . go online to sportsmith fitness products they can also provide you with a new battery as well
the battery is located on the right side of the machine when your are standing in it, push both pedals down with your knees and remove the small cover in front of you carefully .release the pedals , then remove the right side cover (remove the push pins on front and bottom of cover ) it will be a little tricky without removing all the covers but be gentle, do not force it too much. you will see the battery to the upper left. as you will see it is easy to remove and replace
Jan 29, 2011 | Stairmaster 4400CL Stepper
Stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
Jan 23, 2010 | Stairmaster Exercise & Fitness
Tip
Mechanical System Troubleshooting for Stairmaster 4000PT Stepper
  1. Remove the side covers. WARNING: TO REDUCE THE RISK OF INJURY, DO NOT OPERATE THE MACHINE WHILE THE COVERS ARE REMOVED. DO NOT DEPRESS OR RAISE THE PEDALS WHILE ANYONE'S HANDS ARE INSIDE THE MACHINE.
  2. Remove the Poly-V belt and inspect the belt for cracks, fraying or any other unusual or excessive wear.
  3. Spin the alternator pulley to check the bearings. Replace the alternator if any clicking or grinding noises are heard.
  4. Inspect the alternator pulley for wear.
  5. Tighten the transmission pulley set screw to the flat side of the transmission output shaft.
  6. Remove the drive chain and inspect the chain for frozen links. Replace a chain with frozen links.
  7. Tighten the transmission drive sprocket set screw to the keyway in the transmission input shaft.
  8. Spin the transmission drive sprocket input 1 complete revolution. The transmission pulley output should turn 19 revolutions. Replace the transmission if any clicking or grinding noises are heard during rotation or the drive ratio is not 19 to 1.
  9. Remove the step chains and return springs from the main frame of the machine.
  10. Inspect the step chains for frozen links and the springs for corrosion. Replace a chain with frozen links and replace a corroded spring.
  11. Make sure that the step chain connection points pivot freely and have no vertical play.
  12. Remove the pedals, pedal arms, and leveling arms and lubricate according to the maintenance section of the manual.
  13. Verify that the clutch sprockets of the hub assembly spin freely in the forward direction and lock in the reverse direction.
  14. Inspect the hub assembly for wear. The drive shaft sprocket should not move up and down or side to side.
  15. Clean and lubricate the drive and step chains with 30W motor oil.
  16. Reinstall all parts, ensuring the proper tension of the Poly-V belt and the drive chain.
Stairmaster Mechanical System Troubleshooting for 4000PT
Stairmaster 4400 PT Stair Stepper Logo
324 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
