Question about Sanrio Hello Kitty Wireless Microphone one color one size
What frequency does my hello kitty wireless mic work on
What fm station does it work on
How do i tune Mazda Demio (2004 model) radio to Southern African frequencies?
fm frequencies are just that fm frequencies ( not japanese, chinese ,english or anything else
it is a range of frequencies in the fm band that local stations broadcast on
so all you have to do is to turn the tuner knob until you get 107 fm
so as you turn the knob you will loose 89 and it will go probably 90.5 , 100.20, 102.7 etc and if there is a station broadcasting that your radio will pick up it will come in and then fade out as you keep moving the knob
you may have to change the mode as there are fm 1 ,fm 2,fm 3 bands to get your fm 107 as it will depend on what megahertz 107 is operating on
Oct 05, 2015 | Mazda Cars & Trucks
Instructions for hello kitty wireless microphone
I lost it. Please give me a new frequency number. I need it for my kid,s micro.
Jan 03, 2012 | Sanrio Hello Kitty Wireless Microphone ...
How do you auto preset radio stations?
Hello
[1] Press RADIO BAND.AUTO PRESET until the band you want appears on the display [direct power ON]. Each time you press the button the indication changes as follows. "FM" => "AM"
[2] Hold down TUNE+ or --ve until the frequency digits begin to change in the display.
The player automatically scans the radio frequencies and stops when it finda a clear station. If you can't tune in a station, press the button repeatedly to change the frequency step by step.
If FM band is noisy, press the MODE repeteadly until "MONO" appears in the display and the radio will play it monatural. If FM radio signal at your area is very weak, this type of noise may occur. OK.
Sep 28, 2011 | Sony CFD-S350 Radio/Cassette/CD Boombox
What FM frequency does the radio need to be on to use a wireless Disney Mickey mouse microphone?
Each microphone has a different FM Freq. If you can not find a Freq there is a very small hole in the mic near the Mic switch. You will need a jewlers screwdriver to make a freq. adjustment. Hold down the applause button while very close to your FM radio. Use manual tuning on your FM radio until you hear applause. If there is a local station playing on the Freq you can insert the jewelers screwdriver into the small hole and change the FM Freq for the Mic. You only need to make "fractional adjustments" to change the Freq. setting. Once you make a mic freq. adjustment change the radio freq SLIGHTLY up and down until you hear the applause.
This should get anyone going that is having difficulty with this microphone.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Toys
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
Jul 19, 2010 | Delphi SKYFi3 XM Radio Receiver
What is the FM radio frequency to use the Hannah Montana Wireless Microphone?
FM 99.7 works best.... However if you have a local FM station using that freq your out of luck UNLESS your handy with a Jewelers screwdriver. Calling tech support will get you a "sorry" but there is nothing we can do. So if you are one of the unlucky ones with a Local 99.7 FM station here is what you can do.
1) Find a dead spot on the FM radio band either at the very low end or high end of the range. You should hear just fuzz (white noise) on your radio. However, on many newer FM tuners if there is no station broadcast there is nothing but silence.
2) Put batteries in the microphone.
3) Get a really really tiny flat head (Jewelers)screwdriver just like the kind in those eye glass kits they sell at the grocery store.
4) Sit right in front of the radio
5) Insert the screwdriver into the tiny hole in the microphone and tune the microphone until the radio goes quiet (no fuzz sound). Or.... you can keep pressing S to hear a beat and the beat is acutally heard through the speakers.
The hole is located just to the left of the screw that you undid to get at the battery compartment, but it's off center. Inside this hole is a small tuning screw. Slowly, slowly, SLOWLY turn the screw driver until you here a change or interruption in the fuzz sound on the radio speakers. This will indicate you found a compatible frequency. Then even slower - tune back to that "notch" until you hear nothing but silence on the radio. Test it by pressing the applause button "A" or by pressing the mic "M" button and talking.
There are multiple places on the FM dial that will "work" as you tune the little screw but you should have already manually selected where (the FM freq) you want to use your mic.
Once it's working it ain't perfect. I doubt you'd do a serious performance on it, but the kids love it.
The mic quality is not top notch for sure.
Fine tune as necessary....
Kelly
Mar 12, 2010 | Licensed Disney Hannah Montana Wireless...
Wireless FM modulator
first you have to set a channel in your sat radio then tune your car radio to that channel go to menu and then to set fm frequency in your sat radio and choose one try to get one that does not have a station on it whatever you set it at just tune your car radio to that frequency and it will work
Dec 05, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Hannah montana mmicrophone
I found this on Yahoo:
I Have The Directions Here
1. for best proformance please note the following
a. place the FM radio in an area of minimal nosie and interference
b. do not set vol to max
c. has to be within 15 ft
d. hear your own voice, will not be brodcasted over the radio
e. in some areas, all frequencies in 92 to 106 FM range could be occupied by a local radio station. in this rare case, your mic will not be functional
3. move mic close to radio while tuning, tuning into frequnecy may take practice. may need to move your radio dial slowly and sing or talk in to the mic
Buttons on the mic:
A.... Applause
S.... DJ Scracth Efeect
M.... Mic
Source(s): Hanna Montana FM wirless mic instruction manual
Feb 10, 2008 | Audio Players & Recorders
Sanrio Hello Kitty Wireless Microphone  one color one size Logo
42 people viewed this question
Top Sanrio Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Sanrio Toy Expert? Answer questions, earn points and help others
