Question about Xerox DocuColor 12 Printer
Xerox printer has a Power off and turn on message
  • brion29 May 11, 2010
    Should have a code number on screen. If not open front door and push stop button.
    Problem Solver:
  • 7 Answers
U must put some values nvm values. If U didn't. U must say what kind of rip u have and I can send
Posted on Jul 30, 2009
Phaser 8200 won't start
First of all Printer's service
then see what is flashing in your printer's screen
Feb 14, 2014 | Xerox Phaser 8200 Laser Printer
My printer is a Fuji Xerox DocuPrint C2535A.. i have an error message when i want to print something.. it says '009-363'
Hi there!
The message 009-NNN is the REQUEST PARTS message. Depend on your number(in this case 363), the part of your printer need to replace.
Try to turn off, wait atlease 15 seconds and turn on your printer again to see the message clear or not. If not, you have to call Xerox Customer Support for replacement.
Under is original text from Xerox DocuPrint C2535A User Guide.
Please Request
Parts 009-NNN
Switch the printer off and then on. If the error is not cleared, the developer unit needs
to be replaced. Contact our Customer Support Center or your dealers for assistance.
Hope this will help. Thanks for reading
Jul 19, 2011 | Office Equipment & Supplies
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Sys err ou463 Power off and on Xerox N17 printers
Turn the Xerox N17 printer off.
Unplug the AC cord from the wall-outlet.
Plug it back in.
Turn the printer on.
Do you still get the error-message?
Oct 09, 2010 | Office Equipment & Supplies
Xerox fault 37,004.40 : 134924
It tends to be the problem of heater assembly in printer .Ensure you have proper power supply to printer , if there is any interruption of power then printer won,t be having enough power to function properly and you get this error message . To solve these problem completely you need to contact service person to get it serviced .
Hope this helps.
May 03, 2010 | Xerox Phaser 8400 Laser Printer
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
ROS Trouble with Xerox DouPrint N17
The ROS is the laser. Believe me you can replace the machine for less than the cost of a laser. The Polygon motor is most likely bad in the laser. I would guess in the $500 range for the laser
Dec 09, 2008 | Xerox DocuPrint N17 Laser Printer
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
Xerox DocuColor 12 Printer Logo
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
