Question about Samsung Digimax Pro 815 Digital Camera
Lcd i MUST OF PUSHED THE WRONG BUTTON, AND CANT FIGURE OUT TO GET IT BACK. THE PROBLEM IS MY MAIN LCD (REAR) ISNT WORKING AND WHEN I HIT THE LCD BUTTON, THE ONE ON TOP WORKS, IF I HIT THE BUTTON AGAIN THE ONE ON THE SIDE WORKS BUT NOT THE REAR. I CAN BARLY JUST SEE THAT ONE......ITS LIKE I MUST OF HIT A DARKNER OR SOMETHING. I APLOGIZE FOR BEING SO STUPID. BUT IVE HIT EVERY BUTTON AND NOTHING SEEMS TO GET IT BACK.
  • 84 Answers
What probably happened is your backlight went out on your LCD. If it is still covered under a warranty they would replace that. But there aren't any buttons you can push to get it back. You'll have to replace the screen.
Posted on Jul 18, 2007
SOURCE:
While cleaning my step-mother turned her monitor off and cant figure out how to turn it back on
Most monitors have very small switches either on the lower front frame (below the screen), on the right side frame, or in a few cases at the bottom of the frame (cant be seen from the front, unless you duck under it). Hit every one of the buttons in sequence, like 10 seconds apart, to give the monitor a chance to warm up and start. Evidently, stop hitting on buttons when the monitor lights up. Do not worry about hitting the wrong buttons, since they will not accept any commands while the monitor is turned off.
Jul 03, 2011 | Acer Computers & Internet
The main button isnt working and now i cant use the touh screen or even adjust anything on the watch.
You have to visit your nearest watch repair shop. It is not possible to say what's wrong without close inspection.
May 18, 2011 | Kenneth Cole KC1639 Watch
While hooking up battery late night and stupidly working in the dark on my 95 Gs 300. I connected battery wrong and blew out my the main fuse, Alt A100-- after changing it and checked all other fuses are...
Most cars have a emergency fuel shut off in the trunk that shuts down fuel pump when hit in the rear end. Try to push that . Or poor some fuel into injectors then see if it will turn over.
Dec 04, 2010 | 1995 Lexus GS 300
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
I just got a rockchip 2.8" 4gb touch screen mp4 player. The calibration on the screen is messed up. *what i touch isnt what comes up*. I need to find out how to manually reset the whole system back to...
all yo have to do is take a niddle or something skinny and push it in the side hold the hold is hard to see but it will master reset
Jan 04, 2009 | GPS
Rear window on 1989 jeep grand cheerokee went down while i was driving wont go back up.
pull out the bottom door paneling
and reach inside until you touch the window
push on the automatic button and push up
on the window at the same time
if the window isnt all the way down,
just pull the window up with your hand
and push the automatic button
Sep 15, 2008 | 2004 Jeep Grand Cherokee
Lcd
Did you accidentally hit the "DISPLAY" or "DISP" button on the back?
Aug 17, 2008 | Canon PowerShot S100 Digital Camera
Hisense TL2020 LCD TV
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
jb
May 23, 2008 | Hisense TL1700 17 in. LCD Television
15 DAY OLD TV
Make sure you are hitting the right menu button. Samsung thinks they are dummy proofing their tvs. You cant get to anything they do not think is pertinent at the time. Make sure you are hitting the write button on the remote. Try to hit menu on the tv and see if that works.
Feb 04, 2008 | Televison & Video
Accessing sevice menu
i tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Dec 06, 2006 | Toshiba 55H70 55" Rear Projection...
Samsung Digimax Pro 815 Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
