Pixma mp450 error 6500 - Office Equipment & Supplies
What this solution, for error code 6500, please, answer in portuguese, thank you
Posted on Apr 13, 2009
  • carlos Silva Apr 13, 2009
    Please, commen the error
I have Canon Pixma MP450, the error is 5B00? how to Fix it? Now cannot use the printer due to this error. Thank you for your attention
Error 5B00 means that your ink absorber is full. you need to reset the counter protection and replace the ink absorber inside the printer.
Visit the link below for instruction on how to reset the canon mp450 printer EEPROM
Dec 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
Turn on and error 6500 displays? How to fix?
The Service Manual for the MP500, which is very close to the MP450, indicates that the error code of 6500 is a PCI buss error and this is a Service Error Code. Typically this is an internal error of one of the ASCI chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
If you want to take the time to try and repair it, you can take the unit apart and search for a loose connection, or unplug and replug all connections. Other than that, you can sell it for parts.
Good luck
Aug 11, 2010 | Canon Pixma MP450 All-In-One InkJet...
My new canon pixma MP450 has an error code of 6500 on the display panel. Can you please tell me how to fix it
this is printer logic motherboard problem
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .
Hope this helps. Please rate my response.
Have a good day.
Mar 13, 2010 | Canon Pixma MP450 All-In-One InkJet...
What does error 6500 mean?
6500 mean hardware error.In most case error in logic board assembly.Sounds like you need a new printer.
Nov 03, 2009 | Canon Pixma MP450 All-In-One InkJet...
Error Code 6500
Isto é causado pela informação em seu registro. Refira por favor a seguinte ligação e transfira o cuidado avançado de Windows… que você não será… varredura disappointed com AWC e não tentará sua impressora outra vez. A mensagem indicada é um erro, mim está supor.
Apr 11, 2009 | Canon Pixma MP450 All-In-One InkJet...
Error code 6500
Hello you can try
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 10, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Hi, my canon pixma mp450 is not feeding the paper thru properly.
We had the same problem so we opened the screws up at the back, gave it a shake and suddenly a asweet wrapper appeared. We then put the screws back in and it started printing again! Good Luck!
Jan 16, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon printer displays error
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Sep 18, 2007 | Canon Pixma MP450 All-In-One InkJet...
907 people viewed this question
