Question about Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator
How to unplug Jenn Air JS42sefxda evap drain
4 Suggested Answers
  • 1214 Answers
SOURCE: js42sefxda jenn air freezer dripping water from the top vent
Check that the drain tube for the defrosted water is not plugged. Someone on here just the other day had the same exact problem, and that was the problem they had.
Posted on Jan 28, 2009
burdfrenzy
  • 348 Answers
SOURCE: I THINK THAT I HAVE A PLUGGED DRAIN LINE WHICH IS
Best thing to do is pull the plug for 24 to 48 hours. Put towels on floor to **** up the melted water. Plug back in and if everything works the drain is clear. If it refreezes then the defrost timer is bad which is not a cheap cure.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Posted on Dec 23, 2010
Testimonial: "this helped a great deal, the heater is the problem; thank you for your help."
  • 132 Answers
SOURCE: Jenn-Air js42sefxda. Freezer and
There is a defrost timer that normally controls the defrost cycles.
It appears that the defrost timer has failed. A new timer needs to be fitted. a technician can help you with that
Posted on Mar 25, 2011
Jenn-Air js42sefxda. Freezer and fridg won't cool. Ice was built up at the top of the freezer. I turned it off for 24 hours and once the ice melted it operates normally. How do I prevent the ice...
Mar 24, 2011 | Jenn-Air JS42SEFXDA Stainless Steel Side...
I THINK THAT I HAVE A PLUGGED DRAIN LINE WHICH IS RESULTING IN A ICE BUILD UP IN THE EVAPORATOR SECTION OF THE REFRIGERATOR. HOW DO I CLEAN THE DRAIN LINE? MODEL JS42SEFXDA JENN-AIR
burdfrenzy
Dec 23, 2010 | Jenn-Air JS42SEFXDA Stainless Steel Side...
Temperature to low reads -75 at times
That is way too cold. Should be around -10 to +10
It's very common for this fridges to have main board problems. Try to defrost it by unpluging it for 24 hours. There is an on/off switch on top, when you take off that cover by lifting it up.
Jenn-air refrigerator repair in orange county, ca
Feb 06, 2010 | Jenn-Air JS42SEFXDA Stainless Steel Side...
Bad smell from underneath side-by-side Jenn Air fridge - how to access and clean out drain pan?
drain pans are no longer removable. to clean. can remove back panel or btm frt kickplate and look for pan. spray lysol down their and clean out the coils.the only reason it should smell is if anything spoiled in ref. and got into drain system. you can try and vacumm up whats in the pan but you will have little room. unplug ref from wall before you go poking around.
Sep 19, 2009 | Jenn-Air JCD2389G Side by Side...
The refrigerator is not blowing cold air but the fan is working
probably a defrost problem check that the evap coil is not iced up.
possible causes are the heater under the evap coil the defrost board/timer or the defrost thermostat, if you unplug the unit for 24 hrs and let it defros completely and then plug it back in and it works fine for a week or so then you get the same problem, then it is a defrost problem check all three possibilities.
Sep 12, 2009 | Jenn-Air JCD2389G Side by Side...
My jenn air side by side has water puddling in the bottom of the freezer section. I turn off the water supply going to the icemaker etc. still puddles. Is their a condensation line that could be clogged...
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 04, 2009 | Jenn-Air JCD2389G Side by Side...
Js42sefxda jenn air freezer dripping water from the top vent
Jan 28, 2009 | Jenn-Air JS42SEFXDA Stainless Steel Side...
JCD2295HES side by side not working correctly
yes that does sound like a bad evap fan motor then unable to circulate air aorund and off hte evap thus building up frost.you can pull the wire leads of the fan motor and ck for 110v. to confirm that you are indeed getting power to the motor.
Mar 05, 2008 | Jenn-Air JCD2295HES Side by Side...
Getting at a clogged drain in evaporator compartment
The evaporator is in the freezer section. Find the fan, remove the panels panels around it. Good luck.
Dec 26, 2007 | Jenn-Air JS48SEFXDA Stainless Steel Side...
Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator Logo
23 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
