Question about Lanier P165 Handheld Cassette Voice Recorder
Speed on Lanier P-165 keeps changing. How can I fix it?
After recording I try to play back and listen to what has been recorded and it either plays back at a fast speed, plays correctly or is a combination of the both. Is there anything that I can do to fix this problem?
  • 145 Answers
There is a fast play switch on the side of the unit. That switch may be failing. Try moving it back and forth repeatadly to clean up the contacts.
Posted on Feb 02, 2009
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
You can not tell me what setting to use on LANIER P-165 so that i can record someone and how far from them
If you want to record somebody 3-4 feet from you then use the dictate mode. If you want to pick up voices in a large room then use the conference mode, it increases the microphone sensitivity to the maximum level.
Jul 01, 2013 | Lanier P165 Handheld Cassette Voice...
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
HELP!!!!
The only people I know that can still fix old Lanier machines are clearvoice@cox.net.
They are trained on Lanier and worked there for many years.
Dec 05, 2008 | Lanier P160 Handheld Cassette Voice...
Play back up loaded files
if the name has been changed the recorder may not recognize it
Jul 11, 2008 | Olympus DS-2300 Digital Voice Recorder
Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
Lanier P165 recorder instruction manual
The Lanier P-165 has a slide switch on the side for master power off / on. Also the battery contacts get flattened over time, a letter opener can help you get these sprung back out to make contact with the battery. Anything more than that consider it toast, serious professional tape units havnt been made in 4 years now. Its all digital now.
May 21, 2008 | Audio Players & Recorders
Playback speed problems...
The Play button controls speed of play back. If you hold the button two long it changes the speed. Press Play and then release and press again until the speed you are looking for is obtained. Be careful not to push the play button mulitple times once it is correct.
Apr 26, 2008 | Olympus DS-2 Digital Voice Recorder
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Lanier P165 Handheld Cassette Voice Recorder Logo
149 people viewed this question
Top Lanier Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
