Question about Fotis AllMedia Grabber
Allmedia grabber 6.0 serial - Fotis AllMedia Grabber
Igrabber serial number is lost
See https://www.mail-archive.com/byumug-discuss@mac.byu.edu/msg21927.html
Jan 14, 2014 | Geniatech Igrabber One Touch Video Grabber...
How to fix a grabber reacher?
I have a idea to help you .If apart ,you mean the rivets are missing? If this is the issue, find or ask a family member w/ a pop rivet gun.The claws that do the grabbing are stamped,labeled (L)-(R). Reassembling the Grabber w/ the rivet gun wouldn't be too difficult .I could fix your problem, if we were neighbors!
Mar 03, 2013 | Unger NN140 Nifty Nabber Trash Grabber 51"...
Can i connect a samsung camcorder vdp453 to windows7 pls?
Most of these camcorders do not have proper usb support for video, so you'll have to buy a so-called video grabber or capture card. You can plug in the video grabber to usb and then connect dvi or firewire from your camcorder. Install the included software, configure your camera. Then press play and the video grabber will record the input from your camera.
When you buy one of those video grabbers, make sure it's a good one. Make sure powerful and stable software (which is compatible with windows 7) is included. Cheap things usually don't work. I've had this Chinese piece of junk for $10 which lagged and kept crashing my computer. Pinnacle was a lot more expensive but it works great and the fun will last a long time.
Jun 17, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
I need some rubber cup for grabber?
There are small clear colored rubber cups that are approx the same size as the rubber grabbers that are used to old things like small stained glass sun catchers on winders there usage is to be a rubber suction cup. These can be used with perhaps a small amount of alterations like you might have to snip off the part that comes down with the small hole in it to hold the metal hook that holds the suncatcher and you will have to drill a hole into the top part to attacj it to the grabber. Just find a screw that fits if you don't have the original.
Apr 11, 2011 | Ontel Products GOP2-MC18/6 Gopher 2 Pick...
How to get no. Of pixels from given image through java
try this code
import java.awt.image.PixelGrabber;
import java.awt.Toolkit;
import java.awt.Image;
class getpixel2
public static void main(String args[]) throws Exception
Image image = Toolkit.getDefaultToolkit().getImage("D:\\one.jpg");
if(image==null)
System.out.println("NO FIle");
PixelGrabber grabber = new PixelGrabber(image, 0, 0, -1, -1, false);
if (grabber.grabPixels())
int width = grabber.getWidth();
int height = grabber.getHeight();
if (isGreyscaleImage(grabber))
byte[] data = (byte[]) grabber.getPixels();
else
int[] data = (int[]) grabber.getPixels();
for(int i=0;i<data.length;i++)
int r = (data[i] >> 16) & 0xff;
int g = (data[i] >> 8) & 0xff;
int b = (data[i] >> 0) & 0xff;
System.out.println("(R,G,B)=("r","g","b")");
public static final boolean isGreyscaleImage(PixelGrabber pg)
return pg.getPixels() instanceof byte[];
} import java.awt.image.PixelGrabber;
class getpixel2
if(image==null)
else
May 15, 2010 | Computers & Internet
I have a EZ Grabber but do not know how to work it.
had same problem. ensure right selections are made in the souce menu. & that your connectors are out connectors and not ins.
Sep 18, 2009 | Ulead Videostudio 8 for PC
Pansat 2500a Dish Network Key
hola me puedes mandar las key de la pansat 2500
Feb 14, 2009 | Panasonic Televison & Video
Clothes smell of old dirty water, after washing
this will solve your problems
Affresh™ Washer Cleaning Kit Affresh™ Washer Cleaning Kit contains 3 Power Puck tablets and 6 Grit Grabber cloths. The tablets remove and prevents odor-causing residue that can occur in all brands of HE washers. Affresh™ cleaner is a formulated, slow-dissolve, foaming tablet that gets under residue, breaks it up, and washes it away leaving the washer smelling fresh and clean. Simply place one tablet in the wash basket (without clothes) and run a Normal Cycle (hot option) or Clean Washer Cycle. The Grit Grabber™ premoistened cloths have been formulated to penetrate, dissolve and remove odor-causing residue from the rubber door seal. Now consumers can clean where they can't reach with the Power Puck™ tablets and where they can with the Grit Grabber™ cloth. Affresh™ brand is environmentally friendly, safe on septic tanks, and safe for all washer components. Package includes three tablets. Part #W10194073 $10.99
Please remember to leave a solved rating!
Dec 07, 2008 | Whirlpool Washing Machines
Computers & Internet Logo
51 people viewed this question
Top Fotis Computers & Internet Experts
David Payne
David Payne
Are you a Fotis Computer and Internet Expert? Answer questions, earn points and help others
