Question about Cannon Kitchen Ranges
Top oven keeps going out cannon carrick
3 Suggested Answers
  • 32 Answers
SOURCE: I CLEANED MY CANNON CARRICK
More that likely your just got the cleaning solution you used on the igniter/in the burner. Light the burners with a match and let them burn for a little bit of time. This usually works. If not you might have to clean the igniter and make sure it is creating a spark for ignition.
Posted on Mar 07, 2011
  • 43003 Answers
SOURCE: i have a cannon carrick cooker & the main oven flame stays the same size it doesnt go up & down as i think it should although it does cook is there something wrong with it?
does the temperature change when you change it
Posted on Nov 26, 2016
Testimonial: "not really ( maybe slightly)although things cook it takes longer than normal"
Cannon Cambridge glass top
This would require a new hinge for the lid as they have an internal spring offering the resistance to keep the top in the up position
Apr 06, 2014 | Ovens
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
I CLEANED MY CANNON CARRICK COOKER TODAY AND NOW THE IGNITION WILL ONLY WORK ON THE TWO RIGHT HAND HOBS. OVEN ANG GRILL ARE FINE AND LEFT HAND HOBS CAN BE LIT WITH A MATCH.
Mar 07, 2011 | Ovens
Canon Carrick LPG cooker-failure of full flame control bottom oven I have had this cooker for 14 months and used it for 6 months only from new. The bottom main oven has just started to play...
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email info@music-works.uk.com for a JPG.
Dec 01, 2010 | Ovens
I have a cannon p[rofessional. When i turn the oven on the burners ignition keep clicking . Any ideas?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 28, 2010 | Ovens
Cannon Cambridge Double Oven. Main oven not heating up
Problem solved, Turned out to be the flame fail device. Next problem was sourcing part. Turns out that allegedly Cannon is now owned by Hotpoint so sourced part through them
Nov 24, 2009 | Ovens
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
Kitchen Ranges Logo
Top Cannon Kitchen Ranges Experts
paulcarew
Vernon Taylor
 Mikey
Mikey
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
