Question about GE Energy Star WCVH6260F Front Load Washer
G e energy star
Ge energy star will not pump out this happened before but
corrected it self wonder if its the timer? thank you
  • 65 Answers
THE GE WASHERS HAVE A PUMP FILTER BEHIND THE LOWEST PANEL ON THE FRONT. ON THE FRONT OF THE MACHINE AT THE VERY BOTTOM, REMOVE THE THREE SCREWS TO REMOVE THE BOTTOM PANEL AND YOU WILL SEE THE ROUND PUMP FILTER HOUSING. IF ON A PEDESTAL, PLACE A BUCKET IN THE DRAWER AS WATER WILL COME OUT WHEN YOU UNSCREW THE FILTER. IF ON THE FLOOR, TILT MACHINE BACK A WAYS TO GET THE WATER INTO THE BACK OF THE TUB, NOT TOO FAR OR IT WILL COME OUT OF THE REAR VENTS. REMOVE FILTER AND CLEAN OUT. THIS IS THE PROBLEM MANY TIMES.
Posted on Jan 27, 2009
GE Energy Star WCVH6260F Front Load Washer not draining
check ur pump for a clogg or possibly defective pully in pump. have u tried to drain it in all cycles to be sure its not ur timer?
Sep 27, 2014 | Washing Machines
Would drain and checked the drain, not much in there, any other ideas. i get ot 19min on the timer and the washer shuts down. it will not spin.
This is an indication that there is a communication error between the Central Control Unit and the EEPROM onboard the CCU. F01 can also be displayed if the onboard "Pump Driver" fails to engage. Generally in order to correct this failure will require replacing the CCU. There is no way to test and verify if the control board has failed.
Jan 17, 2011 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
My ge profile top load washing machine will not finish it's cycle and empty the water?
Sounds to me that you need a new timer,the timer is responsible for All the functions of a cycle!!! if you remove the timer and take it to an appliance parts store(check the yellow pages) they should be able to supply you with a replacement.
Nov 06, 2009 | GE Profile¿ Arctica® Energy...
The start timer control cycles but nothing happens. The motor seems to gurgle while attempting to fill with water - but no water comes through. We have had this problem before and the repair person...
I bought a new one and installed it myself. hardest part of installing was taking the old unit out. I compared the cost of a second repair of a 10 year old dishwasher vs. purchasing a new one. We also checked the pump and solenoid to find problems that caused the water not to enter the unit. The new one we purchased is much better, quieter, and Energy Star.
Aug 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Drips at water dispenser GE PSC23MGSA BB
If it's a constant drip then you need a new water valve.
Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
How to Reset a GE top load Invensys washer timer?
remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
Oct 31, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260
Quite possible your pump is clogged, you have to dismantle.
Try these sites:
espares.co.uk
RepairClinic.com
AppliancePartsPros.com
Pl rate me.....................
May 31, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
235 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
