Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimste g series green light?
Green light is on what does that mean?
  • Kirby Master
  • 18,424 Answers
That means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
Posted on Jan 21, 2013
Should the green light be on while I am using my Kirby vaccum
If you mean the light on the top or side of the Power Nozzle, yes, it should be on for most uses. You can disengage the belt for other uses. The green light illuminates when the belt is turning the brush roll. So, you see, the green light functions to confirm to you that the brush roll is spinning. For carpet, you would want the brush roll spinning. When I vacuum my comforter or sofa, I don't have the belt engaged because I don't want the roller to grab up my fabric. For that use, the green light is not illuminated.
Oct 11, 2014 | Kirby Vacuums
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
Green light mean
The green light blinking means the belt so slipping. The green light being off means the brush is not spinning at all. The belt needs to be replaced at least twice per year for proper agitation.
Jan 04, 2014 | Kirby Vacuums
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Kirby vacuum g3 green light on roller assembly
belt will be stretched fit new gen kirby belt, copy belts are not worth fitting
Jun 18, 2012 | Kirby Generation 3 Bagged Upright Vacuum
No suction at all on my Kirby just cleaned the brush, etc... had a hard time getting the belt back on... really hate this vacuum cleaner
I have a kirby Diamond series and the 'green light' on the upper right side (while standing behind the vaccum) does not come on and when it doesn't come on I noticed that it does not sound as though it is picking up at all. I have changed the belt, placed a new bag in it and made sure that there is no clogs. What else could it be?
Apr 03, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Green light on power nozzle of Kirby vacuum, Model G7D
The green light is just to inform you that the brushroll is spinning. there is a magnet on the brushroll that makes the green light come on every time it rotates. also why it looks like the light flickers because the magnet only makes contact once per rotation of your brushroll. Let me know if you have any other questions.
Jan 03, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Do i want the green light on or off on kirby upright
It has nothing to do with the green light. Green light simply indicates that brush roll is spinning. If there is no green light:
1 - belt may be broken
2 - Improperly installed nozzle
3 - wrong brush roll is installed
Properly adjust the nozzle - turn the Kirby on. Keep lowering the nozzle till it touched the carpet and you will hear change in sound. Then lower it by one more click.
Rocky
(GoodVac.com)
Mar 30, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby sentria
you have to make sure the green light is on.. in the corner .. and if it is that means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
Jul 05, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
202 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
