Question about Toshiba Satellite M45-S2692 Notebook
BSOD when trying to install Win XP, or boot Win XP from hard drive
BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
  • 3 more comments
  • walter higgins Jan 21, 2013
    Windows 7 didn't work either. I can't seem to boot any bootable dvd in this one, one bootable cds. Gonna try linux.
    Hiren's boot cd to gparted magic boot fine, and I was able to boot xp partition using hiren's boot cd as well. I checked for Toshiba's recovery partition in Gparted, and there was a 200MB mystery partition. If Gparted can't figure out what it is, I assume it's long since been corrupted. The boot partition was fine though. Ubuntu 12.04 LTS booted and worked well.
    Thanks again to all, I appreciate you guys reading this. Somewhere on this website, someone with more grey hair than me probably has an idea what's wrong with this computer (or xp).
    Another note: Following instructions from one of the "suggested solutions" below about wiping drive and reformatting, I booted "parted magic" from Hiren's boot cd again (I called it gparted above by mistake) and noticed during bootup that the kernel could not get ACPI going, and went with HAL. I've also noticed that the dvd drive on the laptop literally hangs down sometimes, and this seems to have interfered with a number of boots. I'm going to try installing XP with ACPI disabled one more time. Again, thank you for any help you guys can offer.
  • walter higgins Jan 22, 2013
    I gave up and installed Ubuntu 12.04 LTS. It runs great. Needs tweeking, but no blue screens. In case someone else runs into this, there is probably a specific method that Toshiba used to install windows xp on this laptop. It's very likely driver related. I read somewhere that the HDD driver might be a cause for this bsod (meaning F6 must be pressed during install to allow for hdd driver install). According to Microsoft, the issue was the Bios itself. I updated the latest bios, and it didn't work (for xp).
5 Suggested Answers
xCAUSALITYx
  • 210 Answers
SOURCE: computer crashing
Its down to the graphics card/graphics controller, the Ati drivers are conflicting with the other hardware and the system files.
The Ati CAT drivers have been very hit and miss for a long time, all I can suggest is that you download older versions of the CAT drivers for your model of graphics card and make sure they match with your CPU model, try them until you get a stable system.
Also, just out of interest what type of CPU, Graphics card and OS are you using - I will do a bit more research for you then.
Cheers
Posted on Jun 14, 2008
gnkanang
  • 63 Answers
SOURCE: Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Posted on Mar 25, 2009
SOURCE: The computer has work fine since we bought it
first check your hard drive..... if you can backup your files then format it and reinstall the operating system.
Posted on Jun 01, 2010
elix0411
  • 3530 Answers
SOURCE: I downloaded and ran a
Welcome to Fixya
This error message usually cause by a boot sector infected by virus, a device driver that the computer boot controller needs is corrupted, hardware issue if there is a resource conflict between the boot controller and another controller or between SCSI devices. If you have the XP cd you may use the cd's repair optiong to fix this problem. If it wont let you do that then the last option you have is to reinstall windows operating system to your computer.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Dec 03, 2010
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
When i am trying to instaling win xp .getting a error message like stop 0x00000007B in a blue screen
hello Shameeralipk,
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
thansk.
Sep 06, 2011 | Acer Extensa 4230 Notebook
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
I am trying to install win xp with sp2 on my laptop. i was using vista on it before . it show this error message; A problem has been detected and windows has been shut down to prevent damage to your...
If you want both OS you need to do a partition on the HD to proceed.IThat what i can figure from your quest.But if you just want XP just do a clean installation of it.
Perform a clean install of Windows XPA clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:313348  (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup programTo perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Oct 06, 2010 | Promise SATA300 TX2plus...
Windows Vista BSOD
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 20, 2010 | Microsoft Windows Vista Home Premium with...
BLUE SCREEN
Then press any key.
Then type "y"
Jun 06, 2010 | Dell Dimension E520 PC Desktop
I hav an acer 5230e ,i want to install window xp but on window setup it shows blue screen error nd appear plz remove newly installed drive nd chkdsk on run /////////////tell me wht i do?
heeey dude ! I had the same problem.. and I just solved out how to fix the problem !.. the only thing you have to do is: Go to your Bios, and switch from SATA to IDE, and then it will be fine :-)
Apr 05, 2010 | Acer Computers & Internet
Insataling windows xp problms
If u just want XP . Source a dos boot ( u can get files from internet), format the HDD .create main partision for windows xp and try installing
May 22, 2009 | Computers & Internet
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Toshiba Satellite M45-S2692 Notebook Logo
259 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
