Zyxel p-2612hwu-f1 qos setup - Computers & Internet
Unable to connect for setup
It could be that some other wireless device has the same IP address as the Zyxel AP. If you have not changed the Zyxel's default IP address 192.168.1.2 , I would recommend it. Try something like 192.168.1.100
Hers the link to the manual:
ftp://ftp2.zyxel.com/WAP3205_v2/user_guide/WAP3205%20v2_1.0.pdf
Mar 13, 2014 | Zyxel WAP3205v2 Wireless N300 Access Point
I have a ZyXEL EQ-660R-F1 and a Linksys Wireless Router (B BEFW1154) that I'm trying to hook up. Can you tell me what I need to do?
Who is your ISP (internet service provider)? Anyway, it is possible to get your set up working. ZyXel is the DSL modem gateway and Linksys, your router/wifi. If you are able to get online by hooking up directly to the Zyxel, then it is possible to add the Linksys to the system.
Dont hook up the Zyxel to the Internet port of Linksys just yet. First you have to configure the Linksys by connecting your PC to it with a cable. Boot up the PC.
Open web browser and enter the address 192.168.1.1 and hit enter. This is the default address of the Linksys. username = admin and no password. It is probably the same as the Zyxel which causes the conflict.
The first set up page may look something like this below.
Change the LAN IP address from 192.168.1.1 to 192.168.2.1
Then click apply...From now on the Linksys IP address is 192.168.2.1.
Now you can connect the Linksys internet port to the Zyxel. Reboot the Linksys and Zyxel.
Your PC should be on the internet after that. To check/setup wifi, you need to log back into the Linksys using the new adress x.x.2.1
Feb 15, 2013 | Zyxel Prestige 660R Router (91004397002)
I am trying to configure my new NBG4115 3G router connexion, but when I try to connect to the Zyxel setup screen via http://192.168.1.1 the Tilgin home screen appears. My present router here in our home is...
Either your web-browser has "cached" the web-page previously delivered by the TILGIN,
or your computer is still connected to the TILGIN.
In the former case, "reload" the web-page.
In the latter case, turn off the TILGIN router, and try again to connect to the ZYXEL router.
Also, check that your network-cables are correctly connected to one of the LAN ports on the ZYXEL router.
May 12, 2011 | Zyxel NBG-415N Router
Zyxel 660HW DSL LED keeps flashing
Try to change the Local or LAN IP Address of your Zyxel to 192.168.5.1 and do not configure the Zyxel router for PPPoE Connection. It should be configured as Obtain IP Automatically or Automtic DHCP.
Oct 21, 2009 | Zyxel Prestige 660HW Wireless Router...
Slow lan (file transfert) with zyxel ES116P and HP ML150 server
Try forcing the ports that the server connects to on the switch to 100Mb Full duplex, sometimes one side negotiates incorrectly, and the switch can set itself to half duplex, even though the other end is set to full duplex.
Feb 17, 2009 | Computers & Internet
I have zyxel nbg334w bought before xmas 08 can connect pc to internet with it but although wireless laptops and games consoles find it still wont connect i am connected to internet via virgin media...
Had the same problem connecting zyxel NGB334W to XBox 360. Other computers and devices would see the SSID but the XBox 360 would not. I had no luck talking to the techs at zyxel, they said it was incompatible with the wireless XBox device. Good news!!! This can be resolved. I went into the setup (192.168.1.1) / Wireless Lan / Advanced / Wireless Advanced Setup. Under the 802.11 mode set to 802.11b. Factory is 802.11b/g and this was not seen. Hope this helps you out.
Jan 30, 2009 | Zyxel Prestige 334 Router
Use zyxel u1496e plus modem windows xp
Default Gateway 192.168.1.1 modem : Zyxel
p/d - green
eth - orange
internet - off Zyxel MODEM interface >> WAN >> Setup WAN >> UId & P/w >> Apply
Internet light will go Green
Nov 19, 2008 | Zyxel U 1496E Plus (AM021000) Modem
Installing wireless router
um is it compatible with vista and/or upgradable?
Jan 15, 2008 | Zyxel Prestige P-330W Wireless Router...
Setting Up QoS (Quality of Service) Settings on the WRT54G
What is QoS? QoS is a popular feature that ?guarantees? better service to selected traffic on a network. The goal in configuring QoS is to give priority and attention to certain devices or services so that they can use the maximum available throughput and speed available on a certain network when it is needed. Accessing the Router?s Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Enabling and Configuring QoS 1. Once in the Router?s Setup page, click on the Applications and Gaming tab. 2. Next, click o n the QoS sub-tab. 3. Select the Enable option to turn on QoS features. NOTE: If you do not see the QoS sub-tab, you must upgrade your router?s firmware to the latest version. See Answer ID 1508 for more information. The WRT54G offers three (3) different types of Quality of Service (QoS) options: MAC Address-based, Application-based, and Port-based. Choose the appropriate type for your needs. · MAC Address-based QoS: In the Device Priority section, you can specify the hardware MAC address of the computer or device that you wish to give priority to. You can assign a Low or High priority for up to two (2) specific MAC addresses found on your local network. · Port-based QoS: In the Ethernet Port Priority section, you can control bandwidth according to which of the physical LAN ports your computer or device is plugged into. You can assign a Low or High priority to computers or devices connected to any of the router?s LAN ports (1 through 4). NOTE: You can also Enable or Disable ?Flow Control? for each LAN port, which is a technique that controls the speed at which data is received. If Flow Control is enabled for a certain port, then a receiving device is not overwhelmed with data as it is coming in. You can even control the flow further by specifying the Incoming Rate Limit to a certain speed. · Application-based QoS: In the Application Priority section, you can control bandwidth with respect to a specific application being used on the network. You can assign a Low or High priority to a particular application or service. There are several pre-configured Web services that use well-known ports, like FTP and HTTP, which you can use. You can also customize up to three different applications by entering an Application Name and the Specific Port # that the software application uses. If you are unsure of the port number that is used for a particular application, contact the software manufacturer for more information. 4. When you have finished configuring QoS settings, click on Save Settings button to save your changes.
Feb 16, 2006 | Linksys (WRT54GC) Router
Computers & Internet Logo
325 people viewed this question
David Payne
David Payne
