Question about Vizio L30WGU 30 in. HD-Ready LCD Television
Unwanted stripes on Vizio TV
I recently received a Vizio 42” flat-panel 1080p Full HDMI set. The image with my HDMI cable is great, but almost always the screen shows about 4” from the right side a thin red & green vertical stripe from top to bottom and 2 gray horizontal stripes near the top of the screen (see attached photos). I’ve tried varying all the Menu options, but the lines remain. Please advise me what to do to remove this lines. Thank you.
kssmybass
  • 4 Answers
SOURCE: The left half of my Vizio tv screen turned black
This is common and very likely the LCD panel has lost its connection at those points around the panel. Most repair shops don't even try to fix it as it is a huge pain to try. You should be able to get a warranty replacement if it is new.
Posted on Nov 05, 2009
SOURCE: Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Posted on Nov 26, 2007
SOURCE: brand new Vizio 42 in from Sams has a 5 inch vertical grey stripe from top to bottom-any help removing it?
take it back!
Posted on Jan 22, 2008
SOURCE: thin white static line at top of screen for some
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Posted on May 06, 2009
SOURCE: 42" Vizio,red stripe down side,and now cutting out!!!
bad lcd panel
Posted on Jun 24, 2009
Need help troubleshooting TV
You need to check your inputs. Make sure your tv is set to the same input that you are plugged into. Ex. If you are plugged into HDMI 1 then your TV SOURCE needs to be on HDMI 1.
Dec 30, 2015 | Vizio 37inch VO37LFHDTV1A FULL HD 1080P...
I connected the cable box to my LG tv with new HDMI cables and the picture is noticeable smaller than the size of the screen. Before, I had the cable from the wall connected directly to the tv and the...
Your cable box and TV are set to different resolutions. Check the setup on both and make sure everything is the same (ie 720p to 720p or 1080p to 1080p) Make sure your cable box can give you 1080p (Nice set, BTW!!). HDMI is supposed to automatically take care of the settings, but it does not hurt to double-check.
Depending on the manufacturer of the cable box, there may be screen setting for "letterbox" which should be selected.
Some TV channels, when redirected through a cable box, simply will not display full resolution (1080p) programming. Your cable TV provider can tell you which channels are displayed in high resolution.
Finally, make sure your cable provider gave you the correct box. Older boxes are not capable of providing 1080p resolution, and since you own a 1080p set, you deserve nothing less!
Jan 30, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
I cannot switch to 1080p on my Vizio. It is a full HD TV but will not do 1080p and I can't switch resolution off of 480p even with a Blu-Ray.
The resolution is not set at the TV, it is set by the video sources. The TV will detect the resolution and display what it is receiving.
1080P signal = 1080p display.
Does it do that on all sources?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 25, 2010 | Vizio Gallevia GV42LF 42 in. LCD...
My new set displays only 480p SD on all my HD channels. Am I missing some settings in the menu's or is something more sinister going on? Any help would be greatful, I'm drowning watching sports!
hi,
u can enjoy full hd 1080p video through only ur tv inputs as 2 component video and 2 HDMI. the tv is seted to receive videos up to the resolution 1080p automatically (need not have any setting). just check the output of ur cable box or BD player, is it outputs full hd. if u are using the tvs internal tuner u will only get 480p.
ok
Dec 20, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
My tv only shows 720p and i am not sure how to adjust it to 1080p ={
You have to adjust the settings on whatever is connected to your television. If you have a bluray player connected to your television with an hdmi cable you should be able to receive 1080p but you have to set the bluray player to 1080i. The tv picks up the signal automatically. From your cable box or satellite tv box you cannot get any more than 1080i from television programs at this time. You can get 1080p from bluray on demand. In certain circumstances you can get 1080p over component cables as well as an hdmi cable but in most cases you will only get 1080i. Once again you have to set your connected device to 1080 to get it on your tv
May 06, 2010 | Insignia 42" LCD Flat-Panel HDTV
Onkyo TX-SR606 takes up to 30 minutes to display 1080p
Please don't rate me for this. Onkyo has been having voltage problems with their HDMI boards in several models. Yours is one of them. They first instructed techs to replace some capacitors, then add some capaictors to repair the voltage problems. Now they want us to replace the HDMI boards but I have yet to receive any (on back-order) Sorry for the bad news.
Mar 23, 2010 | Audio Players & Recorders
How do you set our vizio to 1080p it is currently set at 480p
You really don't think you set the TV for this, if the TV supports 1080p and the device was 1080 capabilities then the TV will recognize this. If you using a cable box make sure your using the HDMI port on the cable box. I have seen in the past cable companies just using the component ports.
Jan 03, 2010 | Vizio GV42L 42 in. LCD Television
How do I get from 480 to 1080p on my tv? I have an HD box on my vizio 42 inch tv but my channels are still showing 480?
1080P is a quality you'll only get with a blue ray quality video. Therefore, you won't get 1080P on cable tv. If your cable provider has HD channels available, you'll be able to get 720 or 1080i quality video (on those channels only). For the best quality, make sure you are using an HDMI cable. Just be sure your cable box supports an HDMI output. Your Vizio definately supports that type of input. If you have a PS3 or alternative blue ray player, you'll be able to watch 1080P.
Sep 12, 2009 | Vizio Televison & Video
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
176 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
