Question about HP Compaq nc6120 Notebook
Can i use only the plug without battery
Hi i want to know if it is right to take out the battery of my portabl pc .and using only the plug since i m workin on my pc at home . because they say that by the time the battery get so weak and better using only the plug . and use the battery only when there is no possiblity for electric resourse.... please give me an idea about this thanks
  • HP Master
  • 4,806 Answers
Hi there
Laptops work fine on AC power only and won't bother it at all, just make sure you do have charge in the battery and that you don't leave it turned on while you go out or to bed as a power surge could knock it out altogether
Good luck
Posted on Jan 26, 2009
My Acer Travelmate 737tlv has a dead battery. Can I use it with the power adapter anyway?
If the battery is dead, you will need to replace the battery if you plan on going portable. Yes you can use your laptop with the power adapter without the battery installed or on. You need to treat this as it was a home computer with a power cord, and becareful not unplugging it until system has fully shut down to avoid surge, short circuit.
Jan 30, 2011 | Acer TravelMate 737TLV Notebook
Shuts down right after start up, shuts off.
Hello there!
You have to check your battery meter. Then try to remove the battery and plug-in your laptop directly to adapter without the battery. Just to make sure if its going to start up when you power up your system using your adapter.
If you need further assistance, please let me know.
Regards,
fossildude
Nov 10, 2010 | Toshiba Computers & Internet
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM049700 need to know what kind of oil to use and replacement sparkplug
we need to know the make of the motor....most use a SAE30 four stroke oil....not sure of the plug without knowing the make of motor.
Jul 23, 2010 | Coleman Powermate 7,000 Watt 13 Hp...
Hi, i have the microsolutions portable bantam backpack model #181100 E/N 00050 Series 6 Driver. What type plug/voltage, etc. do I need to use this thing? any help is greatly appreciated!!!!!!! I know...
First does your bantam,have an adapter for 110,120.or 220 volts? Second is it three or two pringed? Third does your bantam have a battery? Fourth do you travel to europ a lot? Or asia,and have you used your bantam on battery power before? If so does your owner's manuel specifie the configuration of its usage ?
Feb 12, 2010 | Computers & Internet
Can i run the laptop without a battery in it.plugged in with ac adaptor only
Yes, you can.
Laptops can run without battery with the AC, and it's fine, does not harm.
But however, I do not recommend you removing the battery and using the notebook with AC adapter only. The notebook is designed to be portable and with battery plugged in. In addition, using AC adapter only may cause the system to overheat since it is getting and using direct power from the power outlet.
Sometimes when you take out the battery your laptop doesn't work.
But that issue usually is related with some problem with the connectors of your motherboard.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 17, 2008 | Dell Inspiron 2200 Notebook
Sony Vaio Laptop Battery - increase charge
Hi Sony battery,
did you mean to say that you battery only remain at 50% and never exceed this amont ??
Normally all the notebook if you keep charging it should come up to 100%, but only a few case that will face the problem
1.problem with battery itself.
2.problem with ac adapter (I face very much problem here not continues power suplly)
3.problem with motherboard the module that deal with charging battery.
Goodluck,takecare.
May 08, 2008 | Sony VAIO PCG-K35 Notebook
Power not working without being plugged in.
Your battery probably shorted and fried itself when it got wet, so replace the battery (remove the one in it right away), and clean the terminals with a pink pencil eraser right away (even before obtaining a replacement battery).
Be thankful that the PSP still works at all after contacting liquid!
Good luck.
Feb 19, 2008 | Sony PlayStation Portable (PSP) Console
Sony playstation portable
It might be a problem with your battery pack, you can even switch on your psp without battery pack, with the charger plugged in acutally. So a replacement battery will be a good choice for you.
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
HP Compaq nc6120 Notebook Logo
61 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
