Question about Thermador CVS236 36" Cook 'n' Vent System Kitchen Hood
Cvs2 downdraft will not go down. How do I fix this?
0 characters
1 Points
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
Downdraft up and down
Hi do you mean the air is increasing and decreasing on its own
Feb 22, 2008 | Thermador CVS30R Kitchen Hood
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
My thermador stove fan keeps going up and down cvs45r
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Pivot arm in telescoping downdraft system sticks when closing
Having the same problem. Unit worked well for 1 1/2 years and then suddenly it dropped after I was thru using it and pushed the arrow for it to go down after it dropped the power wouldn't turn off - had to unplug it.. Repairman came out , took it out, lubricated it , re-installed and next time it went up fine, vented fine but when it went down it dropped again and power wouldn't turn off again. I am hesitant to call him out again unless I can figure out what else might fix the problem. I have noticed that the top piece now seems to be bowed a bit. I guess I can have him take out the cooktop but think there must be enough room for it if it worked fine for the 1 1/2 years. It is a soapstone countertop.
Dec 28, 2008 | GE Profile JVB67 36" Telescopic Downdraft...
Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Install a Thermador UCV36 cook'n'vent
Hi schmidt_rich,
I'm Harvey the Master Plumber.
Your question is: You took over as owner builder when your builder "took the $ and ran". You are installing kitchen cabs now and discovered the PVC vent pipe (which goes into the foundation and out the side of the house) is in the wrong place for the location of the downdraft unit and integral blower. The vent is actually under the electrical connection panel. You were told initially( 2 yrs ago when you bought the downdraft cook'n'vent) there could be no bends in the exhaust fan route or it would change the effectiveness. Does anyone know if it is ok to put a bend in the connection to the vent? Or do you need to redo your kitchen cabinets?
I can syphathise. I have had to deal with this same problem. I have found that one ell will not degrade the effectiveness enough to notice. If you need more then you may need to adjust cabinets.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut seems a diode fried or still looking for a replacement
Jun 08, 2008 | GE Profile JVB67HWW 36" Telescopic...
How to replace up/down switch in downdraft vent for cooktop
Does any body know where I can get the schematic for the PC Board P/N 959-0138-003 by ACT, Inc.?
Thank you.
Jul 27, 2007 | GE Profile JVB67H Kitchen Hood
Thermador CVS236 36" Cook 'n' Vent System Kitchen Hood Logo
Top Thermador Range Hoods Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Thermador Range Hood Expert? Answer questions, earn points and help others
