Question about Tools & Hardware - Others
Ace model 102 stapler How to load staples? - Tools & Hardware - Others
5 Suggested Answers
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
Posted on Mar 14, 2009
SOURCE: how do I load JT21
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Posted on Aug 30, 2012
How do you load a ace heavy duty clipper stapler model number 82?
I found some information here:
ACE STAPLE Quality Tradition for Over 50 Years
It takes the Clipper Undulated Heavy Duty 3/8" Staples. On the back of the stapler, there is a loading rod. Remove the loading rod and place a set of staples in the chamber, then re-install the loading rod.
Dec 02, 2015 | Heavy Duty Tools & Hardware - Others
How do you open/refill this stapler?
Push the top of the lever located on the back of the stapler.It will pop out on a spring. Slide a new strip of staples in and push spring/rod assemble back in until it clicks into place.
May 31, 2011 | Ace Hardware Ace Staple Gun
How do I load the clipper 700 stapler?
At the back of the stapler, there is a piece that you push in and then pull out. You load the staples in there and then replace the piece you pulled out.
Apr 27, 2011 | ACE Hardware Heavy Duty Clipper Stapler
I have an ACE aircraft aluminum stapler... I bought Ace Heavy Duty Staples 3/8" 10mm Narrow Crown Arrow T50 staples but cannot get the arm to load with them on it.
Possibly you are trying to load it from the back with the arm out. This way does not work. With this stapler you must pull the arm out all the way and then drop the staplers in the bottom. Too easy, right? I felt like a dumb a$$ after fighting this one for an hour. By the way, it will take heavy duty staples but you need to match the item codes printed on the side of the stapler with the box at ACE hardware. Hope this helps... Say "yes" to "was this solution helpful?" so I can know that im not the only one who did this wrong :)
Jan 09, 2011 | Ace Hardware Ace Staple Gun
Hello. I have a model #1000 Swingline Power Gun. It says,the extra heavy duty staple gun on the handle. I would like to purchase a box of 1/4" and 3/8" staples. The gun is so old I don't know the new...
Went to the local hardware and read the labels. The store brand fit and works as good as the original staples. The 1000 has outlasted several of the new fashion staplers. And the local hardware store is an Ace Hardware.
Jan 20, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Can't load staples in high capacity stapler
Try breaking off about 15 staples from the strip.
Dec 24, 2009 | Ace Hardware Ace Staple Gun
Got a black and decker electric stapler given to me but no manual so can't find way to load it. It is a cat. no. 9700 stapler
Look at the back of the staple gun just under the electric cord and you will see a 1/2 loop of spring steel sticking up from the chrome base. Push it down lightly and toward the front of the stapler - when it is all the way forward lift the loop it while in the forward position and while up - draw it back and the will come out of the staple gun.
Sep 29, 2009 | Black & Decker Tools & Hardware - Others
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Can't remember how to load staples in my power shot stapler.
power shot guns have dif crown widths bring the gun to home depot or lowes and match them up or get the model # off the gun
tom
Dec 08, 2008 | Ace Hardware Ace Staple Gun
Tools & Hardware - Others Logo
597 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
