Question about Whirlpool LHW0050PQ Front Load Washer
My washer turns on but doesn't wash.
The washer turns on and the door locks but it doesn't wash. It fills up and drains but doesn't move.
  • armandgonzo Jan 26, 2009
    Thanks, is it something I can do or do I have to schedule a person to come out and fix it?
  • armandgonzo Jan 30, 2009
    I just got clarification on the problem. The washer does not spin and just gets stuck at the wash mode. Is the solution the same?
  • 112 Answers
It`s the motor brushes.
Very cheap and easy to replace.
They are either fixed in by a small spring or just screwed in.
good luck
Posted on Jan 26, 2009
  • Steve Draper Jan 26, 2009
    you can do it.
    Just take all the numbers you can find(model numbers of machine) to an electrical supplier and they will give you the correct parts. Ask for motor brushes. When you see the new brushes you will know what to look for on the motor.
    good luck
  • Steve Draper Jan 31, 2009
    You can easily do it yourself
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
The door was opened while the washer was running
The washer failed to lock the door
Washer temperature control problem
Heater Relay Failure (on main PCB)
The door will not unlock
Washing machine has failed to drain the water
Water fill time out
Water Does Not Drain From Washer
Water fill time out = No Fill
Washing machine door detected as being open
Washing machine has detected an imbalanced load
Washing machine has imbalanced load and will not spin
Motor fault detected
Motor short error
Washing machine has detected an overfill situation
Water leak - Excessive SUDS - Bad water level switch
Water heating error detected
Water heating sensor (thermistor) error detected
Water level sensor fault
Abnormal water temperature detected
Not filling in allocated time
Pump won't empty - not draining
Overflow - overfilling with water
Out Of Balance (OOB) detected
Water temp rising or falling too quickly
Pressure switch
Temp too high on low temp washes
Water leak, Water level has reduced
Motor generator error
Motor error
Sep 30, 2016 | Samsung Washing Machines
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
Started filling, made a loud noise, stopped filling immediately, door wouldn't open. I tried everything to get it to open. Running the spin cycle finally got the door open at the end of the cycle, though...
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board. Motor Control Board 00436461
Nov 22, 2017 | Siemens WFXD5200UC Front Load Washer
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Maytag front load washer model #MAH4000AWW. Just happened! Water fills then nothing. Wife says it "seems" like it wants to do something but doesn't
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Sep 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Kenmore HE2 Plus wont start and it gives code F-21...... the door locks but the washer wont fill up with water.. then it faults out. What can I do?
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
Washer wont work
Does the programmer move or make noises?
It could be one of four things
Faulty programmer (if it does not move or make noises)
Faulty Door lock, (try pushing the door firmly in)
The belt may be broken - If the belt is broken or come off of the wheel then you will be able to see this by removing the top. (always make sure that you remove the electrical plug before investigating)
The brushes on the motor could be worn down
Nov 22, 2008 | Candy Washing Machines
Washer refuses to move to next cycle
Can you still open door when it has filled?If so it is intermittant door lock .If no new progame card required.
Nov 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Whirlpool LHW0050PQ Front Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
