Question about Garmin nuvi 200W GPS Receiver
Screen goes black when I press "finished", for next input.
Garmin 200W instrument. When inputing an address for location, I punch in house number, then finished to go on for street I.D. Screen will go black when I punch in "finished" for next function.
  • bo2et Jan 27, 2009
    Apparently this reply was supposed to give me a solution. I can't find the solution in your reply. You are recommending I go to a source which requires me to join something and pay a fee. I do not want to join anything and why are you trying to charge me for a simple answer.
    Thank you,
Gentlemen, I have not received a reply to date from your outlet. I do not wish to join anything. I just want to know if my unit requires professional repair and who do I go to to have it repaired.
Thank you,
Posted on Jan 27, 2009
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Oct 29, 2012 | Garmin Nuvi 1450 GPS Standard Red LED Wall...
Cant remeber pin number
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
Nov 03, 2011 | Garmin nuvi 200W GPS Receiver
Want to know how to put way point in my etres gamain gps
Adding a Waypoint is not to difficult. You would first of all choose Where To? on the main menu, and then input your main destination. Once the GPS unit has finished calculating your route and ask you to follow the given route, you would then go back to the Main Menu screen and choose Where To? again. You would then input the Waypoint using Favorites, or whichever method you prefer to use. Once the GPS has accepted the destination, and it displays the screen with the large GO button, you would press GO. The next screen should ask you if you want to add this location a a New Destination, or to Add as a Via Point. You would then choose Via Point.
Mar 17, 2011 | Garmin GPS
No matter what address i input, it can find the location but when it start navigate, the map turns out a location in Kansas..i dnt know why is that..i input washington state address
You need to change the State. When you go to put in the address does it show the state as Kansas. If so press change state and change it to Washington.
Jul 19, 2010 | Garmin nuvi 260W GPS Receiver
Where is space bar located on address screen?
The space bar on your unit is on the bottom of the keyboard, next to the "M" key. It looks something like this [, but on it's back. Let me know if this helps.
Jan 04, 2010 | Garmin nuvi 200W GPS Receiver
My grand daughter locked up my garmin nuvi 200. She does not know the pin number she input. Now I can not use it. Can you help?
You can take it to the location where your granddaughter locked it, and it will unlock by itself (this is called the security location). It will then unlock, and you can reset the PIN.
Otherwise, you have to send it in to Garmin with the original receipt and they will unlock it for you. There is no master password.
Oct 21, 2009 | Garmin nuvi 200W GPS Receiver
My garmin 200w shows garmin screen then goes black even with charger plugged in
sorry . some problem with your charger .try using another charger
Sep 20, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 ...enter a Start and End destination!
Yes, you can enter in a specific address as follows:
Press "Where to"
Press "Address"
Select State
Spell City
Enter House Number
Enter Street
Press Save
Press Go
If your Nuvi has acquired a satellite lock, you will then be ready to go.
- Jim
Nov 29, 2008 | Garmin nuvi 200W GPS Receiver
Address
I found out that my road is not on the garmin map,therefore it goes to a road or street
that has the same house number
Hilroy
Apr 23, 2008 | GPS
Garmin nuvi 200W GPS Receiver Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
