Question about West Bend 55108 Espresso/coffee Maker
I have lost the rubber end that covers the nozzle on the espresso
Can I purchase a new one ? Or use it without one ?
  • 8,596 Answers
Here is where you get one:
http://www.focuselectrics.com/finditem.cfm?itemid=2706
-Tha Mp3 Doctor
Posted on Mar 25, 2009
Is it important to use the rubber on the nozzles on frothing milk for cappuccini?
It is not important at all, you have found the easy way, the nozzle is for dummies that cannot figure it out.
Aug 16, 2014 | Krups Coffee Makers & Espresso Machines
Lost nozzle on steam wand of Francis Francis x7
I did a quick search, and unfortunately, your only realistic options are to either fabricate yourself one, or try to get one via the manufacturer.
Sep 02, 2012 | Illy Francis Francis X7.1 iperEspresso...
Adding fluid to the rear end
Hey, Welcome to FixYa!
If you have already purchased your 80-90W gear oil you will notice how the bottle is shaped. Long and has a nozzle at the end. Simply park your truck on flat level ground. Remove the Circle rubber inspection plug on the rear end cover. Then begin filling it with fluid. Continue to add fluid until Oil just starts to run out of the hole. Replace the plug and your all set.
If i helped you please don't forget to rate me. Cheers!
Dec 14, 2011 | 1987 Ford F 150
I am missing the hexagonal key for the D150 Nespresso machine necessary to remove cage, where can I find one
Sept 2012--
I had the same problem. I purchased a used D150 and wanted to make sure it was clean before using it but it was missing the special hex key to take off the nozzle part. Here is my fix-
-Remove the water tank
-Turn the whole machine upside down. You want to remove the stainless steel square plate that holds the nozzle assembly in place. It is held there with 4 security screws. If you don't have a special security screwdriver go ask for one at your local hardware store. Get one with multiple tips as there are a few different ones. Don't try to use a regular screwdriver.
-With your new security screwdriver remove the stainless plate. Under each security head screw should be a lock washer- don't lose them.
-Under the plate should be 4 flat washers- don't lose then.
-With the plate removed you can now use an adjustable wrench to remove the hex washer which holds the nozzle assembly in place.
-Once removed the nozzle assembly will have a small rubber washer/gasket in the center- do not lose this!
-Clean all your parts---I just cleaned the rubber gasket with a cloth with water and put the whole nozzle in boiling water then cleaned it up a bit.
-Put everything back like it was and tighten well.
My used D150 works great and makes an awesome espresso!
Dwight
Sep 01, 2011 | Nespresso D150 Espresso Machine
Need assembly instruction for gaggia titanium steam wand. doesnt seem to go far enough up the tube after i cleaned it
Slide the large sleeve off, now you have just the shorter plastic nozzle with the rounded cap. Unscrew that cap - hold the plastic nozzle with one hand while twisting the cap to unscrew it.
Inside is a hard plastic ring and a soft rubber sleeve. Sometimes the soft rubber sleeve will not come out of the nozzle - if so then just leave it in - but if it will come out, take it out and clean everything really well.
OK ... now put the cap on the steam pipe, then the hard plastic ring, then the rubber sleeve - and slide them up high enough on the pipe - then slide on the nozzle last. Then tighten the cap down on the nozzle until it is gripping good and tight. Then slide the long outer sleeve and you should be good to go.
Oct 01, 2010 | Gaggia Titanium Espresso Machine
No rubber fitting on steam arm
The rubber fitting does 2 things. It splits the steam and it keeps the end from bumping too hard. You don't need it but make sure you clean the steam tube well.
Jan 25, 2009 | Breville ESP8XL Espresso Machine
Need replacement steam wand sleeve
http://saecooutlet.com/ has parts and help for the sirena machine
Jan 22, 2009 | Saeco Starbucks Sirena Espresso Machine
Gaggia Steam Nozzle
There is a sit where you can get the parts for the gaggia it is at WholeLatteLove.
Jan 04, 2009 | Gaggia Classic Espresso Machine
Nozzle won't stay on steam tube
There should be two rubber pieces inside the threaded collar & cap that help produce a pressure fit onto the wand itself. There is a total of five plastic pieces on my steam wand excluding the wand itself on my Via Venezia by Saeco I purchased a year ago. Sounds to me like you lost one of you rubber gromets! Just my thoughts!
Dec 20, 2008 | Saeco VIA Venezia
Need new steam tube
Try this: http://www.smallappliance.com/product.asp?cur=USD&sid=18954&gid=18960&mid=15&pid=7108&prdCls=P&shopBy=Brand
Jun 16, 2008 | Krups Palatino 905-42 Espresso Machine
West Bend 55108 Espresso/coffee Maker Logo
65 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
